I Galaxies as systems extended from the solar system
Galaxies do not adhere to Kepler's laws, which are applicable only to two-body systems, and are instead modeled using Newton's laws. The discussion highlights that galactic behavior is fundamentally Newtonian, though it may require adjustments for dark matter and general relativistic effects. The small sample size of the Solar System raises questions about the validity of extrapolating its dynamics to galaxies. Modified Newtonian Dynamics (MOND) is mentioned as one potential framework, but it is noted that there are multiple modified theories available. The conversation emphasizes the need for further understanding of dark matter and alternative gravitational models.
Martyn Arthur
TL;DR Summary
The application of Kepler's third law to galaxies
Is it a big assumption that Galaxies should follow Kepler's third law with rotation speeds decreasing with distance from the centre. Is the small tet of the behaviour of the Solar System not too small an example to make such a substantial assumption?
Thanks
Martyn
Astronomy news on Phys.org
They don't follow Kepler's laws. Those only apply to two masses.
They are modelled as following Newton's laws (GR corrections are too small to worry about).
With the caveat that you mean Newton's laws not Kepler's the answer is:
1 - no, galactic behaviour is purely Newtonian, we just need to work out what dark matter is.
2 - sort of, we need to include general relativistic corrections to a Newtonian model.
3 - yes, all we need to do is work out how the modified theory, Modified Newtonian Dynamics (MOND), works.
Take your pick which is the correct one...
Likes diogenesNY and russ_watters
Thank you!
Martyn
Technically they apply to problems of central motion in a Kepler potential (proportional to 1/r). The second law applies more generally to any central potential as it is related to conservation of angular momentum. However, the first and third laws are contingent on the problem actually being a Kepler central potential.
The gravitational two-body problem of course reduces to a Kepler central potential problem once the center of mass motion is factored out.
There is more than one modified theory. MOND is not the only game in town and is at best a "toy-model".
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
