Does This Free-Body Diagram for a Forklift Make Sense?
  • Thread starter mcastillo356
  • Tags
    no idea
In summary: You set the load by putting it on the barrow....the user first ascertains the slope and condition of the surface. If the surface is not smooth, the user will need to use caution when setting the load in motion in order to avoid slipping or tripping.Good.The slope and condition of the surface affects how easily the wheelbarrow can be pushed and the amount of load that can be loaded.
  • #36
mcastillo356 said:
when it starts to climb the incline plane (whose angle we don't know; or is it also 40º?);
Hi haruspex!:smile:
The angle must not be 40º, much less instead.
I am trying to make sense of her words at the statement. "Along the handle", she mentions. The only way is to contextualize it. If I'm pushing to deal with a slope, everything tallies: only if I pretend to climb, teacher's statement makes sense, and the force exerted is downwards.
It doesn't mention (the statement) a inclined plane; but neither a coordinate system or any clue to determine the direction of the movement. Anyhow, I've ##\color{red}aimed## to explain what happens on the ##x## axis; I mean, without rise or fall... Well, I'm talking alone again.
I will quote the Physics Graduate:
1- He told me that the only way to represent the exerted force was that it was applied along the handle, this is, downwards.
2- He wrote this for the forum, talking about torques and the posibility to solve this problem fairly well, as it is used to be: with torques:
"The force of gravity generates a counterclockwise torque; then, we need another torque: this torque must be generated by the gardener, and it must have the same value as gravitational torque, but clockwise, because we need a total nule torque. This is not studied in this introductory problem; we only analyse the force (independent of the torque) that produce a linear acceleration".
  • #37
Ok, so the Physics Graduate doesn't understand the question either. That is all utterly useless since we do not have enough information on the geometry of the wheelbarrow.
You have drawn it with the line of the handle passing through the centre of the wheel, but we are not told that, and neither do we know where the mass centre of the barrow+load is.
Call that mass centre O, the line along the handle L, and the point where the wheel contacts the ground C. Call the point on L directly above C the point A.
If we take moments about O, there are only two forces exerting a torque: the vertical reaction from C (anticlockwise) and the force applied along L. Since the latter must be clockwise, we can place O below L.
If the weight of barrow plus load is W, the reaction at C is W+F sin(40). We find that the line OA makes an angle ##\alpha## above the horizontal, where ##W=F\tan(\alpha)\cos(40)##. It can be anywhere on that line.
This gives 86 degrees. That's a lot, but possible if the point A is high and the horizontal distance from O to A is short.
So, no need for a ramp. The question asks for the acceleration and you can calculate one, despite the bizarre requirement on how the gardener applies his force.
  • #38
Yes, indeed
Certain
Yes
Fine
Perfect
Fine
Brilliant
Brilliant. Center of mass estimated
Fine, you've concluded that the center of mass is near to the wheel. That means Newton's second law (inertia) stands down there. Fine. The exerted force must be downwards. No ramp required at all.
I've waved my magic wand and a ramp has appeared.
Thanks!
  • #39
mcastillo356 said:
I've passed the exam: 6,30 over 10. I've passed all the subject. Next week, or in two weeks, I will pay the registration.
Congratulations, señor Castillo! :smile: 👍
  • Love
Likes mcastillo356
