I Gas Density of Lunar Crater Rims: Comet vs. Asteroid Impacts
Gas densities at lunar crater rims differ significantly between comet and asteroid impacts due to the varying condensation behaviors of materials involved. While both types of impacts generate high temperatures and vaporize some materials at the hypocenter, the energy disperses as the crater forms, resulting in lower velocities for ejected soil. Comet impacts may lead to unique crater characteristics since cometary ices do not condense quickly, potentially affecting the distribution of ejecta. On the Moon, the absence of a substantial atmosphere allows fine dust to be accelerated further from the crater, while larger boulders are left behind, creating distinct winnowing effects. Overall, the differences in impact dynamics between comets and asteroids may result in visibly different crater formations on the lunar surface.
snorkack
TL;DR Summary
Properties of vapour driving explosion
I mean - when they form.
What are typical gas densities at lunar crater rim when the crater is made by a comet? An asteroid?
Both a comet and an asteroid, hitting Moon at several km/s, initially heat up to several thousand K, and even asteroid produces some vapour... at hypocentre.
However, by the time a crater rim forms, the blast has spread out a lot. If a crater is 100 km in diametre, then throwing soil 50 km from the centre to the rim requires propelling the soil at 400 m/s... by the time crater rims are formed, the energy of explosion has been transmitted from a small amount of rock moving at several km/s to a large amount of soil moving a few hundred m/s. Which process would be accompanied by drop of temperature - and condensation of rock and iron vapour.
However, cometary ices would NOT be in any hurry to condense!
Does this cause comet craters on Moon to be very different from asteroid craters?
For example... on Earth, Venus and perhaps Mars, air is ahead of soil thrown out of crater. It follows that fine dust and sand in soil are slowed down by air, while boulders continue further, by inertia.
In contrast, on Moon what lies ahead is vacuum, and the steam is behind the soil. It follows that fine dust and sand should be accelerated more and blown further from the crater, while boulders should be left behind.
Are this kind of winnowing effects conspicuous on Moon?
Likes collinsmark
Astronomy news on Phys.org
Also by a "typical" object (asteroid, comet)?
The Moon has some atmosphere though, 0.3 nPa so its not vacuum (still better vacuum than most/all man made vaccuums)
snorkack said:
Summary: Properties of vapour driving explosion
Strength of gravity, the presence of an atmosphere, as well as surface material strength would all play a part in the formation of the crater and ejecta. And of course, the yield strength of the incoming celestial body for atmospheric conditions - does the incoming body explode from the pressure wave within resulting from the drag force of the atmosphere somewhere above the surface, or stay relatively intact to produce a hypervelocity impact upon the surface ( in a no, or thin, atmosphere this would be the case ).
Since the mv^2 kinetic energy is huge, the release of that energy is of several atomic bombs strength.
In no atmospheric conditions, ejecta would be following a ballistic path,
In an atmospheric conditions, large ejecta would follow a more ballistic paths but still suffer from atmospheric drag. Smaller ejecta would probably go pyrothechnic-ish ( its ballistic trajectory ( velocity ) greatly reduced due to the atmosphere ) much the same way as from a volcano, and blanket the surrounding area for several crater radii ( I presume. )
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
