I Gas molecular attraction in the sense of Newton's law
Gas molecular attraction can be observed through astronomical phenomena, where gravity keeps gases in nebulas and stars together, such as in the case of the Sun. The behavior of gases in the atmosphere, including density gradients and buoyancy, supports the influence of gravity on gas molecules. While Newton's law adequately describes the gravitational interactions in typical stars, more complex scenarios like neutron stars require general relativity. Current technology is insufficient to measure the gravitational force between individual gas molecules directly. Overall, these observations illustrate the role of gravity in the behavior and structure of gaseous bodies.
Bernadette
TL;DR Summary
Attraction between gas
Hello
What experiment or observation shows that for atoms, molecules or masses of gas, there is attraction in the sense of Newton's law (universal attraction)?
Bernadette
Astronomical observations would indicate that the gases in nebulas stay together by gravity. Similarly for the sun composed largely of hydrogen atoms.
The atmosphere exhibits all the predicted phenomena of gas under the influence of gravity. Density gradient, buoyancy of less dense gases and pockets of warmer air, the escape of hydrogen and helium from the atmosphere but not heavier gases, and more.
For evidence that gases generate gravity themselves and react to this gravity, astronomical phenomena are perfect examples, as jedishrfu pointed out.
Another example is the theory of stars, which are held together by gravity and hindered to collapse by pressure. For usual stars like our Sun Newtonian theory is sufficient. For, e.g., neutron stars you need general relativity (Tolman-Oppenheimer-Volkoff equation).
The gravitational force between two molecules is too small to measure using existing technology.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
