Gas pressures with (hypothetical) filter
In a hypothetical scenario with two containers of different volumes, a filter allows only one type of gas to pass between them. When 3 moles of Ideal Gas A and 3 moles of Ideal Gas B are placed in Container A, the gases initially distribute evenly when connected. With a filter that permits only Gas B to move, the question arises whether Gas B will equalize pressure across both containers or just its own partial pressure. The discussion highlights that the filter does not do work on the system, suggesting that pressure equalization depends on the properties of the gases and the filter's design. Ultimately, the behavior of the gases in relation to the filter's characteristics and the principles of gas laws is central to understanding the outcome.
funkyfreshcecil
Imagine I have 2 constant-volume, constant-temperature containers. Container A has a volume of 10 L and one Container B has a volume of 5 L.
My hypothetical gases Ideal Gas A and Ideal Gas B have the same properties as each other (temperature, mass, energy, heat capacity, blah blah blah).
If I insert 3 moles of Ideal Gas A and 3 moles of Ideal Gas B into Container A and connect the two containers, I'd expect the pressure to equalize between the containers, and the final distribution of the gases to be
Container A: 2 moles Gas A, 2 moles Gas B
Container B: 1 mole Gas A, 1 mole Gas B
makes sense.
Now, I restart the experiment, but this time I've placed a magic filter (possibly controlled by a demon) that only allows Gas B to pass, and insert it the connection between the two containers.
What would the distribution of the gases be?
Obviously all of Gas A stays in Container A, thanks to the filter.
Would Gas B move to Container B until the total pressure was equal between the two containers? Or would the partial pressure of Gas B move it until the Gas B pressure was equal. Or does it have to do with the number of moles in each container. Or...?
Thanks for any insight anyone who understands ideal gas laws can give!
Doesn't this depend on the properties of this magic filter? (e.g. can it do work?)
Good point.
This magic filter doesn't apply any forces to the gas any more than the container walls do -- it's a Maxwell's demon-ish type filter that simply allows the passage of one type of gas particle but not the other.
For example if the two gases have molecules of different size, and the filter has holes that allow one size particle through and not the other.
Would that count as doing work? I don't think it's adding energy to the system if that happens. It's definitely messing with the entropy though.If no work were being done by the filter, my intuition says that the two containers should still equalize in pressure. Or is it just the case that each gas equalizes in pressure, if it can?
Thanks for your quick response.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
