Gauge Transformations: Can G(t,q) be Expressed Differently?
The discussion centers on the gauge function G(t,q) in the context of Lagrangian mechanics, focusing on its derivatives and transformations. Participants explore how G can be expressed and the implications for quantities like the Euler-Lagrange equations, generalized momenta, and mechanical energy. They clarify that if G is solely a function of q and t, the order of derivatives can be interchanged due to the properties of continuous functions. The conversation highlights the mathematical relationships between the derivatives of G and their significance in mechanical systems. Overall, the thread emphasizes understanding the transformations and expressions of gauge functions in theoretical mechanics.
dynamicskillingme
For a gauge function G(t,q) where
does
or
have any alternative form or can they be expressed in any other way?
Could you give a little more context to your question? I assume you're talking about electromagnetism? Or are you talking about quantum field theory? What is L and L'?
Its a mechanical system, but just working on proofs and theory so
I'm working on proving how different quantities change, such as the euler lagrange equations, the generalised momenta, mechanical energy and power
So for example for the euler lagrange I have
correction
Oh, so you're just talking about Lagrangian mechanics.
If G is a function of q and t, then you have:
\dot{G} = \frac{\partial G}{\partial q} \dot{q} + \frac{\partial G}{\partial t}
So in that case, \frac{\partial \dot{G}}{\partial \dot{q}} = \frac{\partial G}{\partial q}
Oh wow, this is painful how much I overlooked that. Thanks!
A quick question about the same function, would
l%20G%7D%7B%5Cpartial%20q%7D%20%3D%20%5Cfrac%7B%5Cpartial%20%5Cdot%7BG%7D%7D%7B%5Cpartial%20q%7D.gif
be a true statement?
Yes, if G is only a function of q and t.
G is a function of q and t, (G(t,q) to be exact). Could you explain why you can change the order of the derivatives in this case?
If you have a function X(t,q)of q and t, then \dot{X} = \frac{d}{dt} X = (\frac{\partial}{\partial t} + \frac{\partial}{\partial q} \frac{dq}{dt}) X = (\frac{\partial}{\partial t} + \frac{\partial}{\partial q} \dot{q}) X
So \dot{G} = \frac{\partial G}{\partial t} + \dot{q} \frac{\partial G}{\partial q}. Therefore, \frac{\partial \dot{G}}{\partial q} = \frac{\partial^2 G}{\partial t \partial q} + \dot{q} \frac{\partial^2 G}{\partial q^2}.
Similarly, \frac{d}{dt} \frac{\partial G}{\partial q} = (\frac{\partial}{\partial t} + \frac{\partial}{\partial q} \dot{q}) \frac{\partial G}{\partial q} = \frac{\partial^2 G}{\partial t \partial q} + \frac{\partial^2 G}{\partial q^2} \dot{q}
Likes dynamicskillingme
