MHB GCD is same in a field and its superfield.
  • Thread starter Thread starter caffeinemachine
    Field Gcd
In an extension field K of a field F, the monic greatest common divisor (GCD) of polynomials p(t) and q(t) in F[t] is identical to their monic GCD in K[t]. If p(t) and q(t) share a non-trivial common factor in K[t], it implies they must also have one in F[t], contradicting the assumption that they do not. This leads to the conclusion that any common factor in K must also exist in F. Therefore, the GCD remains unchanged when moving from F[t] to K[t]. The relationship between the GCDs in both fields highlights the consistency of polynomial factorization across field extensions.
caffeinemachine
MHB
Let $K$ be an extension field of a field $F$ and let $p(t),q(t)\in F[t]$. Show that the monic greatest common divisors of $p(t)$ and $q(t)$ in $F[t]$ is same as the monic greatest common divisor of $p(t)$ and $q(t)$ in $K$.
Mathematics news on Phys.org
Hint:
Let $p(t)$ and $q(t)$ have a non trivial common factor in $K[t]$. Assume that $p$ and $q$ don't have a non-trivial common factor in
$F[t]$. Then there exist $a,b\in F[t]$ such that $pa+qb=1$. But this contradicts the fact that $p$ and $q$ have a non-trivial common factor in $K[t]$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
