GE initiates testing on second XA100 "adaptive cycle" fighter jet engine
GE has begun testing its second XA100 adaptive cycle engine, a key development in the U.S. Air Force's Adaptive Engine Transition Program, following successful initial tests of the first engine. This new engine promises a 10% increase in thrust, 25% improved fuel efficiency, and enhanced heat dissipation, while also being compatible with biofuels. The XA100 is designed to integrate seamlessly with the F-35 fighter aircraft, marking a significant advancement in military aviation technology. Concurrently, GE announced its split into three separate companies, with the aviation sector retaining the GE name. This restructuring reflects the changing landscape of major corporations, as evidenced by the shift in Fortune 500 rankings over the years.
berkeman
Admin
This is pretty interesting. It sounds like GE and the Air Force have been able to make some good improvements recently:
https://www.ge.com/news/press-relea...&rc_uuid=b1b7f61c-f288-43e1-9587-9f37962fd22a
EVENDALE, Ohio – GE has initiated testing on its second XA100 adaptive cycle engine as part of the U.S. Air Force’s Adaptive Engine Transition Program (AETP). Testing began on August 26, 2021, at GE’s Evendale, Ohio, altitude test facility. This is GE’s final planned prototype engine as part of AETP.
Full-scale prototype engine testing in the AETP program is the capstone of a multi-year technology maturation and risk reduction effort to bring an adaptive cycle engine to full maturity in close partnership with the U.S. Air Force. GE’s first XA100 engine tests began in December 2020, marking the world’s first ever run of a flight-weight three-stream adaptive cycle engine. Tests successfully validated the engine’s ability to deliver transformational propulsion capability to current and future fighter aircraft. Engine prototypes assembled as part of AETP are designed to fit and integrate directly into the F-35.
These revolutionary innovations increase thrust 10%, improve fuel efficiency by 25%, and provide significantly more aircraft heat dissipation capacity, all within the same physical envelope as current propulsion systems. The XA100’s improved fuel efficiency provides significant reduction in carbon emissions. The engine will also operate on any U.S. Air Force-approved biofuels.
More info: https://www.geaviation.com/military...XA100&utm_medium=Inpowered&utm_content=Native
Likes russ_watters, hutchphd, Astronuc and 1 other person
That's kind of sad on the day when GE announced that it is splitting into 3 pieces. The aviation part will retain the GE name.
It doesn't seem like sad news, does it? What were the other two spinoffs, Medical and something else?
EDIT -- Found it: Aviation, Healthcare and Energy businesses
That's kind of sad on the day when GE announced that it is splitting into 3 pieces. The aviation part will retain the name GE.
When I joined GE in 65, we thought the 5 top of the Fortune 500 companies were eternal.
  1. General Motors
  2. Exxon
  3. Ford
  4. GE
  5. Mobil
Far from it. The 2021 list looks far different.
  1. Walmart
  2. Amazon
  3. Apple
  4. CVS
  5. United Health Care
So you now understand financial services thanks to Jack Welch?
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
