MHB General motion in a straight line.
The discussion revolves around calculating the motion of a bird returning to point A after traveling to point B. The user determined the time T as approximately 4.25 seconds using the integral of a velocity function, which resulted in a zero net displacement. The graph of velocity versus time shows that the areas above and below the x-axis cancel each other out, confirming the return to the starting point. The method involved solving a cubic equation derived from the integrated velocity function. Overall, the calculations and graphical analysis support the conclusion that the bird returns to point A.
Shah 72
MHB
In q(c) I calculated the distance using t= 4.25 S . I get S=-3.23×10^-3
I added 5.78m to this which is the distance between A and B, I get 5.78m. Is this the correct method to prove that the bird returns to A. Pls help
Mathematics news on Phys.org
$\displaystyle \dfrac{1}{12}\int_0^T 3t^3-16t^2-10t+60 \, dt = 0$
$T = \dfrac{\sqrt{1105}+5}{9} \approx 4.25$
in the attached graph of velocity vs time ...
shaded area above the x-axis = displacement from A to B
shaded area below the x-axis = displacement from B to A
the two shaded areas sum to zero, indicating a return to the starting point, A
https://www.physicsforums.com/attachments/11188
Thanks so much!
Can I pls ask you
Can you pls tell me how did you calculate that? Did you solve the cubic equation? I don't understand how you got the equation sq root (1105).
I integrated the velocity function and evaluated it from 0 to T and set the result equal to zero.
$\dfrac{T}{12}\left(\dfrac{3T^3}{4} - \dfrac{16T^2}{3} - 5T+ 60\right) = 0$
ignored the T/12 factor & multiplied the terms inside the parentheses by 12 to clear the fractions …
$9T^3 - 64T^2 -60T+720 = 0$
I graphed the cubic on my calculator and found T = 6 was a zero, then used synthetic division to find the quadratic factor …
$(T-6)(9T^2-10T-120) = 0$
$T = \dfrac{10 \pm \sqrt{4420}}{18}$
discarding the negative value for T …
$T = \dfrac{10+2\sqrt{1105}}{18} = \dfrac{5+\sqrt{1105}}{9}$
Thank you so much!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
