General question regarding Momentum
  • Thread starter Thread starter ms. confused
    General Momentum
Negative momentum is possible and relates to the direction of an object's velocity, as momentum is a vector quantity. An object moving in a positive direction has positive momentum, while moving in the opposite direction results in negative momentum. This concept applies regardless of whether a collision occurs; momentum exists for all objects based on their velocity. The discussion clarifies that momentum is not solely dependent on collisions but is inherently tied to the object's movement direction. Understanding momentum as a vector allows for the possibility of negative values based on the object's motion.
ms. confused
General question regarding "Momentum"
Hi! :smile: Is it possible to have negative momentum?
I would think that as long as it's before a collision, this is not possible because an object would be moving forward, therefore having a positive velocity. After a collision (given that it is inelastic), however, the object most likely will move in the opposite direction, in which case the velocity is considered to be negative, which in turn makes the momentum negative.
Does this sound logical, or am I completely missing the point? :rolleyes:
Of course; it is possible for objects to travel either left or right, don't you think?
Yes, but it all depends on whether it is before or after a collision does it not?
Does collision have anything to do with it?
Momentum is not a scalar. Meaning that it isn't just a number like the amount of money you have, or energy and power.
Momentum is a vector, meaning it has direction. Automatically things that are vectors CAN be negative. Take for example velocity or speed. If walking forward is positive then walking backwards is negative. If pushing forward means you've got positive momentum, then striding backwards would mean you have negative momentum. =)
No, not really.
Every object has (a possibly zero) momentum, whether or not it collides with anything.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
