General Relativity & Ether: Clarifying a Contradiction?
In summary: It underscores what I said earlier about the historical context of the term "ether".In summary, the statement is that the General Relativity can be interpreted by speaking of an ether whose state varies from point to point.
DanAil
Hope this question can be quickly clarified:
There was a statement that the General Relativity can be interpreted by speaking of an ether whose state varies from point to point. Is this correct?!
DanAil said:
There was a statement that...
A statement where? You will get better and more helpful answers if we know where you saw that statement, as it can be interpreted in several different ways, some more sensible than others.
Likes DanAil, martinbn and PeroK
I think an aether without a rest frame is no aether. But authors can define terms how they like so I suppose someone who really wanted to could deliberately define the word “aether” to refer to something that would match that qualification. Many people, including myself, would reject such a definition.
Likes DanAil and vanhees71
Only if you are willling to use "ether" as a synonym for "the geometry of spacetime" and nothing else. In particular, as Einstein says in the reference you give, you must "be careful not to attribute to this ether any matterlike properties (e.g., a distinct velocity at each point)." Which defeats the whole purpose of using the term "ether" in the first place.
Likes DanAil, vanhees71, PeroK and 1 other person
Given that Einstein, in the last sentence at that link, says 'one has to be careful not to attribute to this "ether" any matterlike qualities', I think a couple of things stand out. First is the use of scare quotes around the word ether, suggesting to me that Einstein thinks that really it's not a particularly appropriate term.
Second, that it doesn't have any matterlike qualities suggests that he's referring to the Lorentz ether, which is a term usually seen in the context of special relativity. The Lorentz ether has no properties beyond its existence, serving only to pick out one inertial frame as the true reality while all others are in some sense not real. Of course, which frame is so blessed is not detectable, so most people simply ignore the whole concept on the basis of Occam's Razor. I don't see why you couldn't apply the concept to general relativity if you were so inclined - pick some foliation of spacetime and declare it the One True Foliation. Again the choice of which foliation is the One True one is undetectable, so is a free choice. And again, in the modern view Occam's Razor would urge you to reject the concept. This was probably not so clear cut in 1918.
Likes alexandrinushka, dextercioby, DanAil and 2 others
Some people also say that the "ether" of modern physics is the vacuum of quantum field theories. I find this utterly misleading since the word "ether" (or rather "aether"?) is loaded with historical context. In the 19th century it was understood to be some medium whose vibrations are light in the same sense as sound are vibrations of the air. Now in the relativistic context the presence of a medium indeed breaks Lorentz invariance in the sense that there is a reference frame preferred by the physical situation, i.e., the (local) rest frame of that medium. Of course Lorentz invariance is not broken at all simply by the presence of the medium but there is a time-like four-vector field defined by the medium, which is its four-velocity (flow) field.
The vacuum of a QFT, however, is precisely NOT in any way distinguishing any inertial frame from any other by definition, because it's invariant under Poincare transformations. So it's good practice to call the QFT vacuum the vacuum and not "ether" or "aether".
The great achievement of Einstein's relativity (particularly the general one) is that it got rid of the fiction of an absolute space and an absolute time, introduced by Newton (who nevertheless stressed "hypotheses non fingo" ;-)). As already Leibniz stated, there's no observational way (even in Newtonian mechanics) to distinguish one inertial reference frame from any other, but of course Newton could never agree with that statement, because it came from Leibniz ;-)).
Likes Delta2, dextercioby, Dale and 1 other person
Thank you all for the answers - good insights. It makes sense statements made over a century ago to be updated with the current understanding of the subject.
Likes vanhees71
Sagittarius A-Star said:
Einstein formulated this in a letter to Lorentz from June 17th, 1916, in the following way
Yes. That just underscores what I said.
Likes Sagittarius A-Star
Einstein formulated this in a letter to Lorentz from June 17th, 1916, in the following way:Source:
https://einsteinpapers.press.princeton.edu/vol8-trans/250?highlightText=ether
That is a quotation out of context. The paragraph is hypothetical.
I grant you that the general theory of relativity is closer to the ether hypothesis than the special theory of relativity. But this new ether theory would not violate the relativity principle any more. For the state of this guv = ether would not be that of a rigid body in an independent state of motion.
Likes dextercioby, nasu, Sagittarius A-Star and 2 others
Source:
Einstein wrote to Lorentz in German (the native language of them both). The German word for the chemical substance "ether" is "äther" which is transliterated into the English alphabet as aether and normally pronunced in English the same as "ether" but in German is more like "aiter" (whereas if "ether" were a German word it would sound more like "ehter").
Corrections gratefully received from @fresh_42 or any other native German speakers (and I learned my German in Bavaria anyway :wink:)
Likes dextercioby and vanhees71
The German word has several meanings, dependent on context.
Source:
https://de.wikipedia.org/wiki/Äther
Äther is pronounced 'a:ter' with a long 'a' as in 'mad'.
There is a nice anecdote about it.
A surgeon who only cared about his specialty read the headline of an article in a magazine after breakfast:
Einstein abolishes the ether!
Shaking his head, the doctor closed the journal: "A small appendicitis would probably be enough to convince this gentleman of the necessity and usefulness of the ether!"
  • Haha
Likes DeBangis21, pinball1970, alexandrinushka and 4 others
Are you sure? The 'a' in (English) 'mad' has a similar sound to the (German) 'kann': I think 'ä' is more like (English) 'hair'.
Likes vanhees71
'kann' is, well, I cannot type that word in here: '#unt' without the 't' at the end, of course.
I think only in Scotland is 'mad' pronounced as a German 'a' as the 'u' in undo. I learned it as æ (bad, land, sand). 'Mud' has a German 'a' sound.
Here you can click on an audio recording for pronunciation of "Äther":
https://dict.leo.org/englisch-deutsch/äther
Only by a native: think of kann pronounced by an Englishman! Actually I don't think there is any German word with an 'a' as in 'mad'.
I think German long 'a' (Bad, Rad), is closest to English car, father or palm.
Likes fresh_42 and vanhees71
Yes. But 'ä' (sad) and 'a' (car) are different.
The Scottish actually pronounce many vowels as in German. (Not that this helps to understand them.)
  • Haha
FAQ: General Relativity & Ether: Clarifying a Contradiction?
What is the concept of "ether" in relation to general relativity?
The concept of "ether" in relation to general relativity refers to the hypothetical medium that was once believed to fill all of space and allow for the propagation of electromagnetic waves. This concept was eventually disproven by the theory of relativity, which states that the laws of physics are the same in all inertial reference frames.
How does general relativity explain the behavior of gravity?
General relativity explains the behavior of gravity as a result of the curvature of spacetime caused by the presence of massive objects. This curvature is what causes objects to move towards each other, giving the appearance of a gravitational force.
What is the main contradiction between general relativity and the concept of ether?
The main contradiction between general relativity and the concept of ether is that the theory of relativity does not require the existence of a medium (ether) for the propagation of electromagnetic waves, while the concept of ether was a fundamental part of the classical understanding of electromagnetism.
Is there any evidence for the existence of ether?
No, there is no evidence for the existence of ether. Numerous experiments, including the famous Michelson-Morley experiment, have failed to detect any evidence of an ether. Additionally, the predictions of general relativity have been consistently confirmed by experiments, further disproving the need for an ether.
How has the understanding of ether evolved over time?
The concept of ether has evolved significantly over time. Initially, it was believed to be a physical medium that filled all of space. However, with the development of general relativity and the theory of special relativity, the concept of ether was gradually abandoned. Today, the term "ether" is sometimes used in a more abstract sense to refer to the fabric of spacetime itself.
