I General relativity question: Gravity clock
logicalmorality
TL;DR Summary
Would a gravity powered clock increase or decrease speed? For example an hourglass.
Would a gravity powered clock increase or decrease speed? Take an hourglass. It should increase speed as gravity increases because it's powered by gravity... But it should also decrease speed because of general relativity...
What you call a ”gravity powered clock” is not a clock in the sense of relativity. It presumes a particular gravitational field to convert a measurement into a corresponding time.
There can be competing effects. In fact, you can easily stop an hour glass from working at all by letting it be in free fall.
Assuming you mean "an hour glass at fixed altitude", it's rate decreases compared to an atomic clock colocated with it as you increase in altitude. This is because an hourglass (or pendulum clock) must be recalibrated for the local gravitational field strength.
Independent of that, all clocks in a gravitational field run slightly slow compared to clocks at infinity. So once you've recalibrated your hourglass to match a co-located atomic clock, it'll still be running slightly slow compared to a clock at infinity.
Essentially, the problem is, as Orodruin just said, that such "gravity powered" clocks are not reliable clocks if they are moved to different gravitational field strengths.
Likes Dale and PeroK
Your reasoning here is faulty. You can't do physics by waving your hands and stringing words together. You need to use the math of the theory to make predictions and then compare those predictions with what is actually observed. As long as there is a consistent mathematical model of the scenario that makes predictions that match what we observe, it doesn't matter that that model does not match whatever vague intuitive sense you have of what "looks right".
Also, you are making a simple and common but fundamental error: "gravity" in GR is not just one thing. An hourglass with greater "gravity" in the sense of "acceleration due to gravity" will run out faster, as seen by an observer right next to it, if we just take that one effect into account. But "gravity" in the sense of gravitational time dilation is different from "acceleration due to gravity", and deals with what the hourglass's behavior looks like to an observer who is not right next to it. There is nothing that requires what those two different observers observe to be the same.
Further, you cannot make a blanket statement that greater "acceleration due to gravity" always corresponds to greater gravitational time dilation. That is false as a general statement.
Likes Ibix and PeroK
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
