General work of friction question
The discussion centers on understanding the concept of work done by friction and energy loss in two scenarios. For object #1, the work done by friction is -4.73, while for object #2, it is -4.63, leading to confusion about which scenario represents greater work. The negative signs indicate energy consumed, with larger absolute values representing more energy loss. In terms of energy loss for the ball, scenario #1, with a final energy of 0.27, indicates a greater loss than scenario #2, which has a final energy of 0.37. Clarifying whether "greater" refers to magnitude or scalar value is essential for accurate interpretation.
jerad908
General WORK of friction question
energy
if the Work done by friction is -4.73 for object #1 but the work done by friction for object #2 is -4.63, in which scenario is the Work greater - the signs are throwing me off.
Also, let's say the initial elastic energy of a ball is 5 and its final energy is 0.27 (scenario #1) vs its final energy is 0.37 (scenario #2), in what scenario did it lose more energy? I am going to assume its scenario one because 0.27 final energy is less than 0.37 final energy however, the work done is -4.73 and isn't that smaller than -4.63?
Welcome, jerad 908! :cool:
Try to see it as energy consumed (hence the negative sign) by friction between two surfaces or internally by the material of the ball (energy commonly converted to heat).
It depends which work you are referring to (work done by friction or work remaining in the object) and what you mean by greater than (as magnitude or as a scalar).
It might help if you post the question as given to you, word for word.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
