Generalization of Lorentz ether
In summary, the discussion revolves around the challenges to the concept of spacetime in relativity theory. The violation of Bell's inequality is mentioned as a potential challenge, but it is argued that it is not a serious challenge within the classical context. The idea that spacetime may be an emergent phenomenon is also brought up, but it is stated that there is currently no evidence to support this. The possibility of constructing a physical theory without a 4-dimensional spacetime continuum is mentioned, but it is argued that such theories do not yet exist and would still need to explain the success of the current model. Overall, there is no serious scientific challenge to the concept of spacetime in relativity theory at this time.
  • #36
Ilja said:
, I'm not a politician, who knows how to hide the true intentions to get money. I do not even want to learn how to do this
Then this is your choice. You have decided that obtaining the good opinion of others is beneath you. You cannot do that and then blame others for their low opinion of your work. Own your choice.
Ilja said:
No, not amoral enough to hide what is behind the theories, namely a revival of some quite old ideas about the ether
Really? You think that your use of the word "ether" is some sort of a moral imperative. That is just plain silly. What kind of moral system requires you to use a word with negative connotations?
Ilja said:
if I would have been ready to distort the scientific content of my work
You seem to be assuming that the use of the word "ether" is scientific content. It is not. Is there scientific content in the use of the symbol ##\alpha## vs the symbol ##\beta##. Is there some sort of amoral deception or scientific distortion involved when people coined the terms "quark" or "flavor" or "beauty". Of course not.
All your talk about "amoral" and "distortion" is completely irrelevant. Your word choice is nothing more than a word choice.
Likes PeterDonis
  • #37
@Ilja: you claim (iiuc) to have the SM with 3 generations, but I when I searched your paper (0908.0591) for mention of the CKM matrix I found none. Do you derive it somewhere else?
Also, I did not find any discussion about masslessness of neutrinos. (?)
Or, if not massless, a derivation of the PMNS matrix?
  • #38
The aim of developing this ether theory was not at all to obtain some modification of the equation to modify some solutions. It was the problem of quantization. I have started with a simple thought experiment of quantum gravity, the gravity variant of the double slit experiment where a test particle possible measures the position. If the interaction was strong enough, then the position of the test particle will be different for different paths of the particle - and the superposition is destroyed by the measurement. Else not.
Now do this with gravity. Then you have to compare the positions of the test particle. For the two cases, that means, for two different gravitational fields. And now remember GR, diffeomorphism invariance, and the hole argument. And you will see that there is no such thing in GR as "the same position" for different metrics.
But the experiment will be the same, it will have a result. Or the test particle is at the same place, then the interaction was not strong enough and the position was not measured, or it was measured, and the superposition destroyed. So, quantum theory gives an observable which does not exist in classical theory.
So, an additional equation, which allows to define the notion "the same position" for different solutions of GR is simply necessary to compute a prediction for this thought experiment. There was a nice candidate for this - the harmonic condition. And, of course, one wants to have a Lagrange formalism for the resulting theory, that's all. It is the simplest solution for a problem which GR cannot solve but quantum gravity has to solve, to be able to compute the results of this simple thought experiment.
The parameter choice [itex]\Upsilon>0[/itex] leads to nice in principle observable differences, namely stable gravastars and a big bounce instead of a big bang, thus, getting rid of the two most important singularities of GR. And of course this would be visible if the values of [itex]\Upsilon[/itex] would be large enough. Then, the spatially flat universe is the only homogeneous one, thus, clearly preferred for symmetry reasons - a curved one would have to have a center. So, the "in principle observable" is not a problem at all.
PeterDonis said:
No, it means it's speculative. Just as the Standard Model itself was speculative until experiments confirmed its predictions. Work on speculative theories is part of science; however, past history shows that, without experimental input, it's very hard to make progress.
Fine. But I disagree about the role of experiments in the progress. Remember on the greatest success stories of physics at all - atomic theory. How long was it "speculative", in the sense that there was no experimental proof of the existence of atoms? Quite long. Was there no progress in atomic theory over all this time? No, there was a lot of progress. But this progress was mainly explanatory. The things which were already well-known have been interpreted in terms of atomic theory. Instead of simply describing them in terms of unspecified "fields".
If we take the example of atomic theory as a pattern, we should expect that new theories have to start with interpretation and explanation of what has been already reached.
No, the masses themselve are not derived.
There are no reasons to expect they are massless. What the model predicts is that there are right-handed neutrinos, and that they have to be inert. (This also with the additional possibility of exchanging left with right.)
What is predicted are the fermions, the gauge fields, and the charges.
In http://arxiv.org/abs/0912.3892 I give some qualitative considerations which show that the masses of the neutrinos have to be much smaller than those of the other fermions. And, given that the leptons are more closely associated with the neutrinos, one can for similar reasons expect that their masses are lower than quark masses.
The other qualitative prediction is that the massless part - that with exact gauge symmetry on the fundamental level - is U(3).
I suspect one can make some prediction about the smallness of the CP-violating terms. I would guess these terms will be created only by distortions of the ether, thus, may be even different in different regions and times.
In general I would not expect that the ether model will allow to predict all the details from simple first principles and a few qualitative properties of the model, there will be also some quantative material properties of the ether which will influence the masses.
  • #39
? I have decided that to use methods to cheat are beneath me. This changes absolutely nothing about I expect from others. If they would behave like what I would expect from scientists, they would look at the scientific facts, compare what different approaches have reached. I would have no problem with a low opinion if it would be based on some objective arguments. Say, that vacuum Nr. 28450433854592423095843905824905 from string theory gives a description much closer to the SM than my model. What I reject is ignorance as an argument ("your theory is ignored, thus, worth nothing") and the application of criteria which, equally applied to others, would have killed all the "behind the SM" theories together.
The issue is not the word, but the connections between the two scientific theories. My theory of gravity generalizes a theory known as the Lorentz ether in the same way as general relativity generalizes special relativity. There have been some scientific arguments against ether theories, and these are, of course, arguments which my generalization of the Lorentz ether has to be able to answer.
"Answering" them by renaming the theory and distorting its content in such a way that nobody would try to apply these old arguments simply because nobody would see that, in principle, there is a strong enough similarity so that one can try to apply to the new theory too, would be cheating.
No. I assume that the non-gravity limit of my theory of gravity is a theory already known and named "Lorentz ether" is scientific content. And a consequence of this fact is that one can try to apply known arguments against the Lorentz ether also against my theory. Some of them fail for trivial reasons (the Lorentz ether was incompressible, violated the action equals reaction principle by acting but not showing any reaction) because they are no longer applicable to the generalization. But all of them? Some of the positivistic "I cannot see it, thus, it does not exist"-type arguments remain unchanged.
  • #40
Yes, more than two thousand years. But for practically all of that time, it wasn't a "theory" so much as an idea. Not only did the idea make no testable predictions, it didn't even have any structure built up around it. It was just the statement "matter is made of atoms", and nothing more.
Really? What progress are you talking about?
Really? What well-known phenomena were interpreted in terms of atomic theory, before the 1800s, when people finally started to figure out testable predictions from the hypothesis that matter was made of atoms, and then started testing them?
  • #41
Nonsense. There is no rule which says you need to use the word ether. You use it because you like the philosophy and want to promote it, not because of some non existent rule that you are honorably obeying.
You have simply chosen to promote the word ether even to the detriment of promoting your theory. That is hardly some moral choice, just a marketing choice.
But there are no scientific facts supporting your idea, and you have even decided that is "not promising enough" to even try to obtain scientific facts supporting your theory.
Nonsense. Failure to cite your references would be cheating. But having cited your references there is no rule on your naming convention.
Which is probably the real reason that you are reluctant to pursue the experimental aspect as well as the real reason that other scientists are uninterested. If it cannot be detected then it is only philosophy, and an old philosophy that has already been rejected.
  • #42
Let's start with 1738 when Bernoulli published his hydrodynamics, which laid the basis for the kinetic theory of gases. Then, of course, you can count Daltons law of multiple proportions, with its explanation by atomic theory, already a proof of atomic theory. But, sorry, in this case my ether model of the SM would have to count as a proof of ether theory too. And many scientists, like Mach, have rejected atomic theory much later. So, it seems more reasonable to count 1905 as the date when atomic theory was finally supported by experiment.
So we have much more than a century of development of atomic theory, read about its progress in https://en.wikipedia.org/wiki/Kinetic_theory_of_gases#History
  • #43
As I understand it, nobody knew it was the basis for the kinetic theory of gases until the mid 1800s, at least; Bernoulli treated fluids as continuous substances, not as made of atoms.
Yes, published in the 1800s (1803, IIRC).
Not according to almost every physicist of the time; it wasn't until the early 1900s that most physicists accepted atomic theory as proved, and if one had to pick a particular experiment that tipped the balance, it would probably be Perrin's experiments on Brownian motion, which confirmed the explanation of Brownian motion by Einstein using atomic theory in one of his "miracle year" 1905 papers. As you appear to agree.
No, because, as you appear to agree, atomic theory was not "proved" until experiments were done confirming an explanation of something that could not be explained by the theory of matter as a continuous substance (Brownian motion). Your theory is not in that position; you claim to explain something that the Standard Model doesn't, but your theory is not the only theory that claims to explain that, and we have no experiments that distinguish between the various theories that go beyond the Standard Model.
Yes; I already said atomic theory started development in the 1800s.
  • #44
Ok, I could have named a theory which generalizes the Lorentz ether, has a global Euclidean space and absolute time, filled with some condensed matter, those speed of sound is identified with the speed of light, which follows with the continuity and Euler equations classical condensed matter theory equations, and distorts rulers as well as clocks with formulas generalizing those of the Lorentz ether, googledigoog theory instead of ether theory. What would have been the point of this decision?
This is already poor polemics. Note also that even if it would be correct, so what? The answer is clear - it is one of the standard accusations against the ether cranks that they like some classical philosophy and that's why reject modern science.
In fact, my motivation was quite different. The original aim was solving an important problem of modern physics, namely the quantization of gravity. To quantize gravity, I need the key properties of the Lorentz ether. The simple point is that we already know how to quantize condensed matter theories. So, if we have an interpretation of gravity in terms of a completely classical condensed matter theory, including all the things we use if we quantize classical condensed matter theories, we have a way how to quantize gravity.
Cheap polemics. Quantization of gravity is, it seems, not a problem at all, and explaning the quite complex structure of the SM in a simple way not a scientific problem too. And the unification of the SM with gravity is also not a problem.
Feel free to ignore all the problems of modern science beyond the SM as "only philosophy".
But if you think that some "old philosophy" has been rejected, it would be nice to see more than empty claims.
The positivistic arguments Einstein has used for SR he has rejected himself, in his famous conversation with Heisenberg where he has said that it is the theory which decides what is observable. And positivism, which was the leading philosophy of science in the critical time of rejection of ether philosophy, has been rejected as a philosophy of science by Popper 1935.
  • #45
Fine, almost agreement. Even if we put the origin of kinetic theory and thermodynamics in the 1850s, so what, there is a lot of time of theoretical development of atomic theory and increasing certainty that it is the correct explanation up to the time when there was agreement about experimental support.
PeterDonis said:
... you claim to explain something that the Standard Model doesn't, but your theory is not the only theory that claims to explain that, and we have no experiments that distinguish between the various theories that go beyond the Standard Model.
Oh. Which other theory claims to explain as much of the standard model as my theory?
String theory is the theory where our universe is exceptional because it is the only universe which cannot be explained by it. Ok, that's a joke, but the fact remains that string theory tells us, up to now, nothing at all about the particle content of the SM. LQG does not even have this aim, afaiu. GUTs and supersymmetry postulate much larger groups, which, for unknown reasons, are then effectively reduced to the SM subgroup. Why this subgroup instead of another one remains unclear, as well as what would be the advantage of the larger group.
  • #46
The various standard model extensions based on supersymmetry, etc. You discount these, but your reasons are similar to the reasons why others discount your theory: personal opinions about what a theory that "explains" the SM should look like. And unless and until some experiment can decide between them, we won't be able to progress any further than that.
Likes Dale
  • #47
I disagree. Explanatory power is essentially the same as predictive power - with the difference that what is "predicted" was already known before. So, postdiction instead of prediction, which, common sense tells us, is clearly weaker. But, nonetheless, you can compare different theories which postdict/explain the SM by their predictive power in the usual way. So, there is more to this comparison that personal opinion only. The usual way to compare the predictive power of theory - Popper's criterion of empirical content - works as usual.
So, what could falsify supersymmetry? How many QFTs are there which do not have any supersymmetric extension, so that observing them would falsify supersymmetry? String theory gives at least an answer, with its $10^{300}$ or so different candidates on the landscape. What is "personal opinion" in this question, instead of a simple application of Popper's empirical content?
  • #48
Failure to discover particles predicted by it. As I understand it, some of the simpler supersymmetric extensions of the SM have already been ruled out by LHC data.
  • #49
Ok, as far as a particular supersymmetric theory contains definite values for the masses. But this was not exactly my question, because it was I have asked about the explanatory power. Is there some property of the SM (like, say, the three generations) which is explained by supersymmetry?
  • #50
OK at this point everyone has said their piece. Since both philosophy and "beyond the standard model" are off topic for this forum, it is time to close the thread.
Likes vanhees71
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Feedback and Announcements
  • STEM Academic Advising
