Generating Entangled Electron Pairs
In summary: Thanks PeroK. But how would they achieve two entangled electrons one of Up spin and one with Down spin. Is it electron decay ?That's not entanglement. That's two electrons each with a definite spin state. Entanglement is where the two electrons have a single (shared, as it were) spin state. This is where quantum entanglement differs fundamentally from the classical example I gave.
RobbyQ
25
I have read, what I believe, misleading articles about generating entangled electron pairs. Some suggesting the electron is split. But this isn't possible because it's an elementary particle with charge/mass and Spin properties. So how do we achieve generating entangled electrons with opposite spin? Or is the concept of pairing a superposition of Spin for the same electron? Or is it electron-positron pairing?
In theory, any pair of particles can become an entangled system. Entanglement often arises from conservation laws. E.g. if a particle with zero spin decays into two particles of non-zero spin, then the spin state of the resulting particles is entangled in order to conserve the overall spin of zero.
In classical physics, the same would apply. If an object with zero momentum and zero angular momentum explodes into two pieces, then the momentum and angular momentum of each piece must be equal and opposite. That's a sort of classical entanglement.
Likes vanhees71 and RobbyQ
Until you tell us what you've read we can't say whether it is wrong or you misunderstood it.
As well as the general principle that @PeroK mentions above (pretty much any interaction leaves the products entangled in some way) you might find https://arxiv.org/abs/1508.05949 interesting - a technique for spin-entangling two electrons.
Likes RobbyQ, PeroK and vanhees71
An electron-positron pair can arise from the decay of a neutral boson, for example.
And is that shared spin state defined by a single wave function for the two electrons?
Likes PeroK
Yes. Technically the mathematical characterstic that identifies it as an entangled state is that the two-electron wavefunction cannot be expressed as the product of single-electron wavefunctions. If they are not entangled, then the wavefunction can be expressed as a product of single-electron wavefunctions.
Likes vanhees71, PeterDonis and RobbyQ
FAQ: Generating Entangled Electron Pairs
What is quantum entanglement?
Quantum entanglement is a physical phenomenon that occurs when pairs or groups of particles interact in such a way that the quantum state of each particle cannot be described independently of the state of the others. When entangled, the state of one particle instantly influences the state of the other, no matter how far apart they are.
How are entangled electron pairs generated?
Entangled electron pairs can be generated through several methods, including spontaneous parametric down-conversion, quantum dots, and certain types of particle collisions. One common method involves using a nonlinear crystal to split a photon into two lower-energy entangled photons, which can then interact with electrons to create entangled electron pairs.
What are the applications of entangled electron pairs?
Entangled electron pairs have numerous applications in quantum computing, quantum cryptography, and quantum communication. They are used in quantum key distribution (QKD) for secure communication, in quantum teleportation to transfer quantum states, and as fundamental resources in various quantum algorithms and protocols.
What challenges exist in generating and maintaining entangled electron pairs?
One of the main challenges is decoherence, where the entangled state is disrupted by interactions with the environment. Maintaining coherence over long distances and timescales is difficult. Additionally, generating entangled pairs with high efficiency and fidelity, as well as detecting and measuring them accurately, are significant technical challenges.
How is entanglement verified experimentally?
Entanglement can be verified through various experimental techniques, such as Bell test experiments, where violations of Bell inequalities indicate entanglement. Other methods include measuring correlations between the properties of the entangled particles, such as their spin or polarization, and comparing these measurements to the predictions of quantum mechanics.
