Generator design
  • Thread starter Thread starter rcb787
The discussion centers on seeking engineering assistance for a generator design idea to assess potential risks. Participants express willingness to help with conceptual questions regarding the generator's type, size, and electrical specifications. They inquire about previous experience in building similar projects and the available fabrication tools. This collaborative approach aims to ensure safety and feasibility in the design process. Engaging with knowledgeable individuals can significantly enhance the project's success.
rcb787
I have an idea but need an engineer to help figure out if im gonna destroy stuff or not
Welcome to PF.
We can probably help with some conceptual questions if you want. What kind of generator is it? What is the generator type? Approximately what physical size and electrical specs are you shooting for? Have you ever built something like this in the past? What fabrication tools do you have available to build this?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
