- #36
- 3,028
- 1,557
That's very clearyfying. Thanks RedX!
RedX said:Hi everyone,
Just out of curiosity, does anyone know why the second line of eqn (5.10) is valid?
The reason I ask is because that form for the creation operator is derived in eqn (3.21) under the assumption of a free-field theory.
Why is the same form still valid in the interacting-field theory? Srednicki took great care later on (e.g., eqns 5.17, 5.18, 5.19) to make the interacting-field theory give the same result as the free-field theory, but seemed a bit careless in not explaining why you can use eqn. (3.21) for the creation operator in eqn (5.10) for the interacting-field theory.
ansgar said:"Let us guess that this still works in the interacting theory as well. One complication is that a^dagger (vec k) becomes time dependent..."
i.e. we define that a should work in the same way but also time dependent due to interactions.
See Weinberg for futher information.
xepma said:So in a free field theory you have truly solved the time dependence of the operator / Fourier component a(k,t).
But in the interacting case the field obeys the interaction version of the equations of motion, which is non-linear (there's a phi^3 term present in these equations). As a consequence the equations of motions of all the a(k,t) are coupled and highly non-linear. It becomes practically impossible to solve these, so there is no way to tell how a(k,t) at a later time depends on the a(k', t') at an earlier time. In fact, the only way to try to resolve the time-dependent structure of a(k,t) is through perturbation theory.
ansgar said:what happens if you actually is doing the math for the RHS of that equation? what does it become?
Use
[tex]
\phi(x)=\int d^3 \tilde k [a(k,t)e^{ikx}+a^\dagger(k,t)e^{-ikx}]
[/tex]
which according to xepma is true
where now the a is the annihilation operator for the true vacuum [tex] |\Omega \rangle [/tex]
msid said:Sorry, I still do not get it. Isn't [tex] |<k,n|\phi(0)|0>|^{2} [/tex] dependent on 'k'? Could you please elaborate?
ansgar said:you might want to go back to basic QM...
it is a number since phi(0) is a number
here is a good review of those particular chapters from srednicki
www.physics.indiana.edu/~dermisek/QFT_09/qft-II-1-4p.pdf
Avodyne said:[tex]\sum_n |\langle k,n|\phi(0)|0\rangle|^{2} [/tex] depends on k, but not on any other 4-vectors. Since it is a scalar, it can depend only on k^2 = -s.
xepma said:But in the interacting case the field obeys the interaction version of the equations of motion, which is non-linear (there's a phi^3 term present in these equations). As a consequence the equations of motions of all the a(k,t) are coupled and highly non-linear. It becomes practically impossible to solve these, so there is no way to tell how a(k,t) at a later time depends on the a(k', t') at an earlier time. In fact, the only way to try to resolve the time-dependent structure of a(k,t) is through perturbation theory.
RedX said:Never mind. I got it. It wasn't exactly pretty, so I probably didn't do it the best way, so I won't write the details here.
Basically you have this:
(1) [tex]
\int d^3x e^{-ikx} \bar \partial_0 \phi(x)
[/tex]
and for the time derivative of [tex]\phi(x)[/tex], use:
[tex]\dot{\phi}=i[H,\phi]=iH\phi-i\phi H [/tex]
Then show that (1) operating on |0> gives zero, (1) operating on [tex] a^\dagger(q)|0>[/tex] is zero unless q=k, in which case you get just |0>.
I think that's enough to prove that (1) = a(k)
RedX said:I have a question about this. Suppose you can solve for a(k,t) in an interacting theory. Does this mean you can calculate scattering amplitudes at finite times? So say I begin at t=-10, and want to figure out the probability amplitude of observing a state at t=129. Then can I say this is equal to:
[tex] <0|a(k_{final},t=129) a^\dagger(k_{initial},t=-10)|0>[/tex]
But I'm having trouble picturing this. Doesn't the Fock space get screwed up, because if you begin with one particle, all sorts of things are happening such as loops involving other particles. In other words, don't you have to extend your Fock space for virtual particles that might be off-shell?
In perturbation theory, is there an assumption that at t=+-infinity, that all interactions are turned off? Otherwise, wouldn't the Fock space have to include off-shell momenta?
xepma said:I'm not convinced this is enough. You would need to see if it holds for all ppssible states.
turin said:I think that you must restrict to the case pA.pB = -|pA||pB| (where A and B are the incoming particles), and therefore restrict the set of Lorentz transformations to rotations and only longitudinal boosts. I'm pretty sure that's what Weinberg means, but I don't have his book, so I can't check. The cross section is invariant to longitudinal boosts, but not transverse boosts.
[tex]A^{\varepsilon /2}=\exp[({\varepsilon /2})\ln A].[/tex]Lapidus said:why is equation 14.33, [itex] {A^{\varepsilon /2}} = 1 + \frac{\varepsilon }{2}\ln A + O({\varepsilon ^2})[/itex] true?
Take the equationLapidus said:What [itex]O({\varepsilon ^0})[/itex] terms? How to match them? Also, what are the [itex]O({\varepsilon})[/itex] terms?
