Geometry problem involving dot/cross product
  • Thread starter Thread starter hanelliot
    Geometry Product
hanelliot
Let r be a line and pi be a plane with equations
r: P + tv
pi: Q + hu + kw (v, u, w are vectors)
Assume v · (u x w) = 0. Show that either r ∩ pi = zero vector or r belongs to pi.
n/a
I get the basic idea behind it but I'm not sure if my "solution" is formally good enough. I know that cross product gives you a normal to a plane, which is u x w here. I also know that the dot product = 0 means that they are perpendicular to each other.. so v and (u x w) are perpendicular to each other. If you draw it out, you can clearly see that r must be either in pi or out of pi. Is this good enough to warrant a good mark? Thanks!
r: P + tv
if r is parallel to pi, but not "in" pi their intersection will not be the zero vector, it will be the empty set
try the separate cases when P is "in" pi, and when P is not "in" pi and try and see if you can show whether any arbitrary point on r is in, or not in P, knowing that v = a.(uXw) where a is some non-zero constant
you are right, my mistake
I can show that with intuition and a sketch of plane/line but not sure how I should go about proving it formally.. maybe this Q is that simple and I'm overreacting
as you know
v.(u x w) = 0
then
v = au + bw
for constants a & b - why?
equation of you line is P + vt
now, i haven't tried, but using your equation of a line & the equation of a plane, considering the following cases, should show what you want:
Case 1 - P is a point in pi. Now show any other point on the line, using the line equation, satisfies the equation defining pi.
Case 2 - P is not a point in pi. Now show any other point on the line, using the line equation, does not satisfy the equation defining pi.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
