Gerotor style turbine , or gasoline engine
In summary, the conversation discusses the potential efficiency of gerotor style pumps in comparison to conventional water turbines, and the possibility of using gerotor technology in gasoline engines. The main points are that gerotor pumps have two rotating, balanced parts and can operate at slow water flow, potentially making them more efficient than turbines. However, other factors such as compression and heating must also be taken into account when considering efficiency. The conversation also mentions the potential for a silent and efficient gasoline engine using gerotor technology, but acknowledges that there are other factors to consider in engine design as well.
Low-Q
Gerotor style "turbine", or gasoline engine
Hi,
I have read a bit about gerotor style pumps. It seems to me that there is only two rotating, balanced parts. If water pressure can enter on one side, the water have no where else to go than through the gerotor before it can continue. The difference from a gerotor and a conventional water turbine is that if you stop the turbine, water can still flow through it. However, if we stop the gerotor, water will also stop flowing. This enables great power output even at very slow water flow.
So in my opinion, a gerotary style power generator should be far more efficient than a turbine.
To the gerotor gasoline engine idea:
As described above, a gerotor has two rotating, balanced parts - that's all. What if the change in volume between inner and outer gear acts like pistons in a normal engine. Shouldn't it be quite possible to make a very efficient and silent gasoline engine that is true rotary - with no vibrations?
I know that a Wankel engine have rotating parts, but the "piston" in a Wankel engine is actually moving up and down as a piston because the shaft is not centered on the rotating part, and makes lots of vibrations as well.
Vidar
No, that is no basis for concluding that the gerotor is more or less efficient than other pumps.
To consider efficiency, you also must consider what the pump does to the fluid other than move it. Compression, and heating must be considered in addition to leakage. And those things depend on the fluid. Air? Water? Hyraaulic oil?
Related to Gerotor style turbine , or gasoline engine
1. What is a gerotor style turbine?
A gerotor style turbine is a type of internal combustion engine that uses a rotor and stator design to create a continuous flow of air and fuel. It is commonly used in small engines, such as those found in lawn mowers and chainsaws.
2. How does a gerotor style turbine work?
A gerotor style turbine works by using a rotor with small lobes that rotates inside a stator with larger lobes. As the rotor turns, it creates chambers between the lobes that are filled with air and fuel. This mixture is then compressed and ignited, producing energy to power the engine.
3. What are the advantages of a gerotor style turbine?
One of the main advantages of a gerotor style turbine is its compact size and lightweight design, making it ideal for small engines. It also has a simple and efficient construction, with fewer moving parts compared to other types of engines. Additionally, it has a high power-to-weight ratio and can run on a variety of fuels, including gasoline and diesel.
4. What are the limitations of a gerotor style turbine?
One limitation of a gerotor style turbine is its relatively low efficiency compared to other engine types. It also tends to produce more noise and vibration, which may be a concern for some applications. Additionally, it may not be suitable for larger engines that require more power and torque.
5. How does a gerotor style turbine differ from a gasoline engine?
While both a gerotor style turbine and a gasoline engine use internal combustion to generate power, they have different designs. A gasoline engine typically has a piston and cylinder setup, while a gerotor style turbine uses a rotor and stator design. Additionally, a gasoline engine has a reciprocating motion, while a gerotor style turbine has a rotational motion.
  • General Engineering
  • Aerospace Engineering
  • Classical Physics
