Get the current and the EQs of Motion of the Dirac-Lagrangian density
The discussion focuses on deriving the current and equations of motion from the Dirac-Lagrangian density. The current derived differs from the provided one by a constant factor, which is deemed acceptable since any scalar multiple of a conserved current is also conserved. The equations of motion for the left-handed and right-handed components of the Dirac field are derived, but the initial solutions do not match the expected results. The participants clarify that the Lagrangian should be expressed in terms of the left and right components, leading to a simplification that allows for the application of the Euler-Lagrange equations. Ultimately, the conversation emphasizes the importance of correctly defining the Lagrangian and the transformation properties of the fields involved.
  • #51
For 1 perfect, but then in 2. you are going backwards, you already know the expression of ##\mathscr{L}(\psi, \bar{\psi})##. What I tell you is much more simple, just compute ##\gamma^5 \psi_L## and ##\gamma^5\psi_R##
  • #52
NOTE: I do not explicitly show computations on ##\bar{\psi_{L,R}}##; it is analogous.
2. Compute ##\gamma^5\psi_{L,R}##
$$\gamma^5 \psi_{L,R} =\frac 1 2 \gamma^5(1\mp \gamma^5)\psi=\frac 1 2 \gamma^5 \psi \mp \frac 1 2 \psi$$3. How does ##\psi_{L,R}## transform under this transformation?
Applying the transformation to ##\psi_{L,R}## we get
$$\frac 1 2 (1\mp \gamma^5) e^{i \alpha \gamma_5} \psi=\frac 1 2 e^{i \alpha \gamma_5} \psi \mp \frac 1 2 \gamma^5 e^{i \alpha \gamma_5} \psi$$
4. Use 2. and the series expansion of ##e^x## to simplify 3.
Well, we get
$$\frac 1 2 (1+ i \alpha \gamma_5 + ... ) \psi \mp \frac 1 2 \gamma^5 (1+ i \alpha \gamma_5 + ... ) \psi$$
But how can I use 2. to simplify it even further?
  • #53
We are working with ##\psi_{L,R}## so it's always a good idea to write all the expressions with ##\psi_{L,R}##, this actually simplifies 2. and 3. a lot.
Then for 3, you need to use all the terms, so the dots are only hidden you relevant information, write the expansion explicitly to all orders.
  • #54
If what I did at #52 is not what you meant regarding 2. 3., then I have no clue... could you please give an explicit hint?
Then you say I have to include all terms of the series expansion... there are infinitely many though! I must be missing your point...
Bottom line is this: I think I need explicit hints regarding 2. 3. and 4.
Thanks
  • #55
What you did in 2 and 3 is OK, but you have the result involving ##\psi##, while we are working with ##\psi_{L,R}##, so try to write the result in terms of ##\psi_{L,R}##.
For 4. you should know that
$$e^x=\sum_{n=0}^\infty \frac{x^n}{n!}$$
here I'm writing the infinite terms.
Likes JD_PM
  • #56
$$\gamma^5 \psi_{L,R} =\frac 1 2 \gamma^5(1\mp \gamma^5)\psi=\frac 1 2 \gamma^5 \psi \mp \frac 1 2 \psi = \frac 1 2 \gamma^5 (\psi_L + \psi_R) \mp \frac 1 2 (\psi_L + \psi_R)=\frac 1 2 (\gamma^5 \mp 1) \psi_L + \frac 1 2 (\gamma^5 \mp 1) \psi_R$$
$$\frac 1 2 (1\mp \gamma^5) e^{i \alpha \gamma_5} \psi=\frac 1 2 e^{i \alpha \gamma_5} (\psi_L + \psi_R) \mp \frac 1 2 \gamma^5 e^{i \alpha \gamma_5} (\psi_L + \psi_R)=\frac 1 2 ( 1 \mp \gamma^5)e^{i \alpha \gamma_5} \psi_L + \frac 1 2 ( 1 \mp \gamma^5)e^{i \alpha \gamma_5}\psi_R$$
Note: Here I assumed that ##e^{i \alpha \gamma_5}## and ##\psi_{L,R}## commute.
$$\frac 1 2 ( 1 \mp \gamma^5)e^{i \alpha \gamma_5} \psi_L + \frac 1 2 ( 1 \mp \gamma^5)e^{i \alpha \gamma_5}\psi_R=\frac 1 2 ( 1 \mp \gamma^5)\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!} \psi_L + \frac 1 2 ( 1 \mp \gamma^5)\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!}\psi_R=\frac 1 2 ( 1 \mp \gamma^5) \psi_L \sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!} + \frac 1 2 ( 1 \mp \gamma^5)\psi_R \sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!}=\gamma^5 \psi_{L,R}\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!} $$
5. Substitute in 1. and should be straightforward to see that is not invariant unless ##m=0##.
$$\mathscr{L} = i\bar{\psi_L} \not{\!\partial}\psi_L + i\bar{\psi_R} \not{\!\partial}\psi_R - \bar{\psi_L} m\psi_R - \bar{\psi_R} m\psi_L$$
It does not look straightforward to me that it is not invariant unless ##m=0##; I guess there has to be something wrong at 4. ...
  • #57
You can still simplify 2. What are the values of
$$\frac{1}{2}(\gamma^5 - 1)\psi_L, \qquad \frac{1}{2}(\gamma^5 - 1)\psi_R, \qquad \frac{1}{2}(\gamma^5 + 1)\psi_L, \qquad \frac{1}{2}(\gamma^5 + 1)\psi_R$$
I think that maybe it will be easier for you to work with ##\psi_L## and ##\psi_R## separately, so the equations read:
$$\gamma^5 \psi_L = \frac{1}{2}(\gamma^5 - 1)\psi_L + \frac{1}{2}(\gamma^5 - 1)\psi_R$$
$$\gamma^5 \psi_R = \frac{1}{2}(\gamma^5 + 1)\psi_L + \frac{1}{2}(\gamma^5 + 1)\psi_R$$
  • #58
I guess you want me to expand it out
$$\gamma^5 \psi_{L,R} =\frac 1 2 \gamma^5(1\mp \gamma^5)\psi=\frac 1 2 (\gamma^5 \mp 1) \psi_L + \frac 1 2 (\gamma^5 \mp 1) \psi_R=\frac 1 2 \gamma^5 \psi_L \mp \frac 1 2 \psi_L + \frac 1 2 \gamma^5 \psi_R \mp \frac 1 2 \psi_R$$
By the way: Do you agree on what I did at 4.? (at #56)
  • #59
No, what I want you to prove is
$$\gamma^5\psi_{L,R}=\mp \psi_{L,R}$$
Likes JD_PM
  • #60
Alright. Could we postpone such a proof (I've been trying it for over 2 hours and got nothing...)? I'd like to prove the non-invariance of the Lagrangian (unless ##m=0##) first.
So following the steps:
2. Compute ##\gamma^5\psi_{L,R}## (I assume it for now)
$$\frac 1 2 ( 1 \mp \gamma^5)e^{i \alpha \gamma_5} \psi_L + \frac 1 2 ( 1 \mp \gamma^5)e^{i \alpha \gamma_5}\psi_R=\gamma^5 \psi_{L,R}\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!} = \mp \psi_{L,R}\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!}$$
But I still do not see how can we plug the above results into the below Lagrangian to check invariance...
If you think it would be more useful to first prove 2. please let me know but please tell me what's the trick because I am completely stuck.
Thanks.
  • #61
Well, we can leave 2 for later if you want, although is really very easy once you realize. I give you more hints, let's define the matrices
$$P_L=\frac{1-\gamma^5}{2}, \qquad P_R=\frac{1+\gamma^5}{2}$$
Then, obviously ##\psi_L=P_L \psi## and ##\psi_R=P_R\psi## compute
$$P_L\cdot P_R = \frac{1}{4}(1-\gamma^5)(1+\gamma^5), \qquad P_R\cdot P_L = \frac{1}{4}(1+\gamma^5)(1-\gamma^5)$$
Then compute ##P_R\psi_L## and ##P_L\psi_R##, can you see it why
$$\gamma^5 \psi_{L,R}=\mp \psi_{L,R}$$
3 is OK, but again, you can simplify it a lot, try to compute the commutator
$$\left[(1\pm \gamma^5), e^{i\alpha \gamma^5}\right]$$
And proof that
$$\psi_L\rightarrow e^{i\alpha \gamma^5}\psi_L, \qquad \psi_R\rightarrow e^{i\alpha \gamma^5}\psi_R$$
4 is not correct, notice that an expression like ##\psi_L\gamma^5## makes no sense because ##\psi_L## is a row vector while ##\gamma^5## is a matrix, so makes no sense to talk about the commutator of ##\psi_L## and a matrix like ##e^{i\alpha \gamma^5}##, so no they don't commute. Maybe you can try to use 2. to compute first what is the value of
$$\gamma_5^n\psi_{L}, \qquad \gamma_5^n\psi_{R}$$
Likes JD_PM
  • #62
OK thanks to your hints at #61 I got it! :smile:
$$\gamma^5 \psi_L = \frac 1 2 (\gamma^5-1) \psi_L + \frac 1 2 (\gamma^5 -1) \psi_R = \frac{1}{4}(\gamma^5 - 1)(1-\gamma^5)\psi + \frac{1}{4}(\gamma^5 - 1)(\gamma^5 + 1)\psi $$
We note that the second term vanishes due to ##(\gamma^5 - 1)(\gamma^5 + 1)=(\gamma^5)^2-1=1-1=0##
Thus we end up with
$$\gamma^5 \psi_L = \frac{1}{4}(\gamma^5 - 1)(1-\gamma^5)\psi = -\frac{1}{4}(1-\gamma^5)(1-\gamma^5)\psi = -\frac 1 4 \psi - \frac 1 4 \psi + \frac 1 4\gamma^5 \psi + \frac 1 4 \gamma^5 \psi = -\frac 1 2 (1-\gamma^5) \psi = -\psi_L$$
Analogously we get
$$\gamma^5 \psi_R = \frac 1 2 (\gamma^5 + 1) \psi_L + \frac 1 2 (\gamma^5 + 1) \psi_R = \frac{1}{4}(\gamma^5 + 1)(1-\gamma^5)\psi + \frac{1}{4}(\gamma^5 + 1)(\gamma^5 + 1)\psi = \frac 1 4 \psi + \frac 1 4 \psi + \frac 1 4\gamma^5 \psi + \frac 1 4 \gamma^5 \psi = \frac 1 2 (1+\gamma^5) \psi = \psi_R$$
QED.
And proof that
This is what I have got far; let's prove first that ##\psi_L\rightarrow e^{i\alpha \gamma^5}\psi_L##
Note that I am going to apply the given transformation ##\psi\rightarrow e^{i\alpha \gamma_5}\psi##
$$\psi_L = \frac 1 2 (1- \gamma^5) e^{i \alpha \gamma_5} \psi=\frac 1 2 e^{i \alpha \gamma_5} (\psi_L + \psi_R) - \frac 1 2 \gamma^5 e^{i \alpha \gamma_5} (\psi_L + \psi_R)=\frac 1 2 ( 1 - \gamma^5)e^{i \alpha \gamma_5} \psi_L + \frac 1 2 ( 1 - \gamma^5)e^{i \alpha \gamma_5}\psi_R=\frac 1 4 ( 1 - \gamma^5)e^{i \alpha \gamma_5} (1- \gamma^5) e^{i \alpha \gamma_5} \psi + \frac 1 4 ( 1 - \gamma^5)e^{i \alpha \gamma_5} (1+ \gamma^5) e^{i \alpha \gamma_5} \psi$$
The second term vanishes, so we get
$$\psi_L = \frac 1 4 ( 1 - \gamma^5)e^{i \alpha \gamma_5} (1- \gamma^5) e^{i \alpha \gamma_5} \psi = \frac 1 4 e^{2 i \alpha \gamma_5} \psi + \frac 1 4 \gamma^5 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5} \psi - \frac 1 4 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5} \psi - \frac 1 4 \gamma^5 e^{2 i \alpha \gamma_5} \psi$$
And here's where I am stuck in. I've been trying to use the commutator you provided
$$\left[(1 - \gamma^5), e^{i\alpha \gamma_5}\right]=(1 - \gamma^5)e^{i\alpha \gamma_5} - e^{i\alpha \gamma_5}(1 - \gamma^5)=e^{i\alpha \gamma_5}-\gamma^5 e^{i\alpha \gamma_5}-e^{i\alpha \gamma_5}+e^{i\alpha \gamma_5} \gamma^5$$
But I still do not see it.
Am I on the right track?
Should I keep trying to solve for one of the commutator factors and get something like ##\psi_L = ... \left[(1 - \gamma^5), e^{i\alpha \gamma_5}\right] ...## ??
Thanks.
  • #63
Perfect, note that was as simple as
$$\gamma^5\psi_{L,R}=\gamma^5\frac{1\mp\gamma^5}{2}\psi = \frac{\gamma^5\mp \gamma_5^2}{2}\psi = \frac{\gamma^5\mp 1}{2}\psi = \mp \frac{\mp\gamma^5+1}{2}\psi=\mp \psi_{L,R}$$.
For 3., for a general operator ##A## and a general analytic function ##f(x)##, do you know what is the value of the commutator
$$[A, f(A)]$$
Likes JD_PM
  • #64
Beautiful! 😍
$$[A, f(A)]$$
I'd say
$$[A, f(A)] := A f(A) - f(A) A$$
Right?
  • #65
JD_PM said:
Beautiful! 😍
I'd say
Right?
What is ##[A, A^n ] ## for ## n \geq 0 ##? Now, assuming that ##f(A)## can be Taylor expanded, what can we say about ##[A,f(A)]##? (if ##f(A)## can't be represented as a Taylor expansion, it is a bit more tricky).
Likes JD_PM and PhDeezNutz
  • #66
$$[A, f(A)]$$
After some googling I found that given two operators ##x_1## and ##x_2## with a constant commutation relation ##c##, such that ##[x_1, x_2]=c##, it can be shown that
$$[x_1, f(x_2)]=cf'(x_2)$$
So in answer to you question (I guess you really meant ##[A,f(x)]## instead of ##[A,f(A)]##); we get
$$[A,f(x)]=kf'(x), \ \ \ \ \ \ [A,x]=k$$
If you really meant ##[A,f(A)]## we get
$$[A,f(A)]=g f'(A)=0, \ \ \ \ \ \ [A,A]=g=0$$
But I still do not see how is ##[A,f(x)]## going to help me in order to move forward in 3. (work shown at #62)...
Source: see page 4 of attached PDF.
  • #67
Nop, I mean ##[A,f(A)]##, don't you see why this can help you to compute the commutator we are interested in?
$$\left[(1\mp\gamma^5),e^{i\alpha\gamma^5}\right]$$
Note that ##e^x## is an analytic function.
Likes JD_PM
  • #68
Ahhh OK; applying it to our case I get
$$\left[(1\mp\gamma^5),e^{i\alpha\gamma^5}\right]= k (i\alpha e^{i\alpha\gamma_5})$$
But now my question is: isn't ##k=0##?
By definition I get that
$$k:=[(1\mp\gamma^5),\gamma^5]=0$$
  • #69
Yes, so you have it
$$\left[(1\mp \gamma^5), e^{i\alpha\gamma^5}\right]=0$$
Does this help you to prove that
$$\psi_L\rightarrow e^{i\alpha\gamma^5}\psi_L, \qquad \psi_R\rightarrow e^{i\alpha\gamma^5}\psi_R$$
Likes JD_PM
  • #70
OK I was at this point
Do you agree so far? If yes, could you please give me a hint on how could I use ##\left[(1- \gamma^5), e^{i\alpha\gamma^5}\right]=0## to show that ##\psi_L\rightarrow e^{i\alpha\gamma^5}\psi_L## ?
Thanks.
  • #71
Thanks.
You know how ##\psi## transforms, right? Write ##\psi_L## in terms of ##\psi##, apply the transformation to ##\psi## and then show that the result can be written as ##e^{i\alpha\gamma^5}\psi_L## .
  • #72
Yes, that's what I am trying. Let's show in detail what I've been doing (it is an extension of what I've done in #62)
By definition we have
$$\psi_L := \frac 1 2 (1- \gamma^5)\psi$$
Applying the given transformation ##\psi \rightarrow e^{i \alpha \gamma_5} \psi## we get
$$\psi_L = \frac 1 2 (1- \gamma^5)e^{i \alpha \gamma_5} \psi$$
We know that ##\psi=\psi_L + \psi_R##; plugging it into the above equation we get
Let's work out the term ##\frac 1 4 ( 1 - \gamma^5)e^{i \alpha \gamma_5} (1- \gamma^5) e^{i \alpha \gamma_5} \psi## explicitly
$$\frac 1 4 ( 1 - \gamma^5)e^{i \alpha \gamma_5} (1- \gamma^5) e^{i \alpha \gamma_5} \psi= \frac 1 4 e^{i \alpha \gamma_5}e^{i \alpha \gamma_5}\psi + \frac 1 4 \gamma^5 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5}\psi-\frac 1 4 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5}\psi-\frac 1 4 \gamma^5 e^{i \alpha \gamma_5} e^{i \alpha \gamma_5}\psi=\frac 1 4 e^{i \alpha \gamma_5}e^{i \alpha \gamma_5}\psi + \frac 1 4 \gamma^5 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5}\psi-\frac 1 4[\gamma^5, e^{i \alpha \gamma_5}]_+ e^{i \alpha \gamma_5} \psi$$
Now let's work out the term ##\frac 1 4 ( 1 - \gamma^5)e^{i \alpha \gamma_5} (1+ \gamma^5) e^{i \alpha \gamma_5} \psi## explicitly
$$\frac 1 4 ( 1 - \gamma^5)e^{i \alpha \gamma_5} (1+ \gamma^5) e^{i \alpha \gamma_5} \psi = \frac 1 4 e^{i \alpha \gamma_5}e^{i \alpha \gamma_5}\psi - \frac 1 4 \gamma^5 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5}\psi+\frac 1 4 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5}\psi-\frac 1 4 \gamma^5 e^{i \alpha \gamma_5} e^{i \alpha \gamma_5}\psi=\frac 1 4 e^{i \alpha \gamma_5}e^{i \alpha \gamma_5}\psi - \frac 1 4 \gamma^5 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5}\psi+\frac 1 4 [ e^{i \alpha \gamma_5}, \gamma^5]e^{i \alpha \gamma_5}\psi$$
Noticing that the commutation relation yields ##[ e^{i \alpha \gamma_5}, \gamma^5]=0## we get
$$\frac 1 4 ( 1 - \gamma^5)e^{i \alpha \gamma_5} (1+ \gamma^5) e^{i \alpha \gamma_5} \psi = \frac 1 4 e^{i \alpha \gamma_5}e^{i \alpha \gamma_5}\psi - \frac 1 4 \gamma^5 e^{i \alpha \gamma_5} \gamma^5 e^{i \alpha \gamma_5}\psi$$
Putting both worked-out terms together we end up with
$$\psi_L = \frac 1 2 (1- \gamma^5) e^{i \alpha \gamma_5} \psi = \frac 1 2 e^{i \alpha \gamma_5}e^{i \alpha \gamma_5}\psi-\frac 1 4[\gamma^5, e^{i \alpha \gamma_5}]_+ e^{i \alpha \gamma_5} \psi$$
And here's where I am stuck. How can I show that ##\frac 1 2 e^{i \alpha \gamma_5}e^{i \alpha \gamma_5}\psi-\frac 1 4[\gamma^5, e^{i \alpha \gamma_5}]_+ e^{i \alpha \gamma_5} \psi=e^{i \alpha \gamma_5} \psi?##
I guess that it can be shown using the commutation relation we found out at #69 but I still do not see it :( (not due to a lack of effort; I've been over 3 hours thinking how...)
Any help is appreciated.
Thanks.
  • #73
My advice: Keep it simple.
Remember how easy was to prove ##\gamma^5\psi_{L,R}## and how complicated you made it? Well, to prove this is even simpler, really.
Try to play with these ideas:
What does it mean that ##\left[(1\mp\gamma^5),e^{i\alpha\gamma^5}\right]=0##?
Where can you make use of that?
I think you should put aside your computations, take a new paper and try to start again the proof, without looking at your previous calculations and trying to come up with new ideas.
Likes JD_PM
  • #74
Ahhh gosh! You're absolutely right!
$$\psi_{L,R} := \frac 1 2 (1 \mp \gamma^5)e^{i\alpha \gamma_5}\psi = \frac 1 2 \Big( [(1 \mp \gamma^5), e^{i\alpha \gamma_5}] + e^{i\alpha \gamma_5}(1 \mp \gamma^5)\Big)e^{i\alpha \gamma_5}\psi=e^{i\alpha \gamma_5} \frac 1 2 (1 \mp \gamma^5) e^{i\alpha \gamma_5}\psi = e^{i\alpha \gamma_5} \psi_{L,R}$$
QED 😍
  • #75
OK so here we go again
2. Compute ##\gamma^5\psi_{L,R}## (proved)
3. How does ##\psi_{L,R}## transform under this transformation? (proved)
$$\psi_{L,R}\rightarrow e^{i\alpha\gamma_5}\psi_{L,R}$$
$$\psi_{L,R}\rightarrow e^{i\alpha\gamma_5}\psi_{L,R}=\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!}\psi_{L,R}$$
Alright I see now why you suggested the following
We get (recalling that ##n## are all natural numbers)
$$\psi_{L,R}\rightarrow e^{i\alpha\gamma_5}\psi_{L,R}=\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!}\psi_{L,R} = \sum_{w=0}^\infty \frac{(i \alpha)^w}{w!}\psi_{L,R} \mp \sum_{m=1}^\infty \frac{(i \alpha)^m}{m!}\psi_{L,R}$$
Where ##w=0,2,4,6...## and ##m=1,3,5,7...##
$$\gamma_5^w\psi_{L,R}=\psi_{L,R},\qquad \gamma_5^m\psi_{L,R}=\mp \psi_{L,R}$$
Is this what you get at 4.?
Thanks.
  • #76
QED 😍
I think that you have a typo and you have a ##e^{i\alpha\gamma^5}## extra, right? You mean
$$\psi_{L,R} := \frac 1 2 (1 \mp \gamma^5)e^{i\alpha \gamma_5}\psi = \frac 1 2 \Big( [(1 \mp \gamma^5), e^{i\alpha \gamma_5}] + e^{i\alpha \gamma_5}(1 \mp \gamma^5)\Big)\psi=e^{i\alpha \gamma_5} \frac 1 2 (1 \mp \gamma^5) \psi = e^{i\alpha \gamma_5} \psi_{L,R}?$$
Yes, but note that ##(\mp)^w = 1## and ##(\mp)^m=\mp##, so you can join all the terms by writing
$$\gamma_5^n\psi_{L,R} = (\mp)^n\psi_{L,R}$$
You can use this inside the expansion, and then undo the expansion (resum the series), this will give you a nicer way to express the transformation.
  • #77
That's right.
OK so we can write it more compactly
$$\psi_{L,R}\rightarrow e^{i\alpha\gamma_5}\psi_{L,R}=\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!}\psi_{L,R} = \sum_{n=0}^\infty (\mp)^n \frac{(i \alpha)^n}{n!}\psi_{L,R}$$
Thus we can assert that
4. Use 2. and the series expansion of ##e^x## to simplify 3. (done)
Let's go for 5.
Let's first show that the Lagrangian is invariant when ##m=0##
The Lagrangian when ##m=0## is
$$\mathscr{L} = i\bar{\psi_L} \not{\!\partial}\psi_L + i\bar{\psi_R} \not{\!\partial}\psi_R=i\psi_L^{\dagger} \gamma^0 \gamma^{\mu}\partial_{\mu}\psi_L + i\psi_R^{\dagger} \gamma^0 \gamma^{\mu}\partial_{\mu}\psi_R$$
We analogously get the transformation for ##\psi_{L,R}^{\dagger}##
$$\psi_{L,R}^{\dagger}\rightarrow e^{-i\alpha\gamma_5}\psi_{L,R}^{\dagger}=\sum_{n=0}^\infty \frac{(-i \alpha \gamma_5)^n}{n!}\psi_{L,R}^{\dagger} = \sum_{n=0}^\infty (\pm)^n \frac{(i \alpha)^n}{n!}\psi_{L,R}^{\dagger}$$
We now apply the transformations we got to the Lagrangian
$$\mathscr{L'} = i\sum_{n=0}^\infty (+)^n\frac{(i \alpha)^n}{n!}\psi_{L}^{\dagger} \gamma^0 \gamma^{\mu}\partial_{\mu}\sum_{n=0}^\infty (-)^n \frac{(i \alpha)^n}{n!}\psi_{L} + i\sum_{n=0}^\infty (-)^n \frac{(i \alpha)^n}{n!}\psi_{R}^{\dagger}\gamma^0 \gamma^{\mu}\partial_{\mu}\sum_{n=0}^\infty (+)^n\frac{(i \alpha)^n}{n!}\psi_{R}$$
We'll all be happy if ##\sum_{n=0}^\infty (+)^n\frac{(i \alpha)^n}{n!}\sum_{n=0}^\infty (-)^n \frac{(i \alpha)^n}{n!}=1## and ##\sum_{n=0}^\infty (-)^n \frac{(i \alpha)^n}{n!}\sum_{n=0}^\infty (+)^n\frac{(i \alpha)^n}{n!}=1## which is clearly not the case.
So I guess I am missing something here...
  • #78
Still in 4. It is better to resum all the terms so, what is the value of the sum
$$\sum_{n=0}^{\infty}(\mp)^n\frac{(i\alpha)^n}{n!}$$
Also, I think I will never insist sufficiently in that ##e^{i\alpha \gamma^5}## is a matrix and ##\psi_{L,R}## is a vector, therefore an expression like $$e^{-i\alpha\gamma^5}\psi^\dagger_{L,R}$$ makes no sense.
Likes JD_PM
  • #79
Ahhh I assume that what you meant is this: you want to get back to exponents
$$\sum_{n=0}^{\infty}(\mp)^n\frac{(i\alpha)^n}{n!}=e^{\mp i\alpha}$$
So we end up with 4. as follows
$$\psi_{L,R}\rightarrow e^{i\alpha\gamma_5}\psi_{L,R}=\sum_{n=0}^\infty \frac{(i \alpha \gamma_5)^n}{n!}\psi_{L,R} = \sum_{n=0}^\infty (\mp)^n \frac{(i \alpha)^n}{n!}\psi_{L,R}= e^{\mp i\alpha}\psi_{L,R}$$
My bad, I always forget it. Actually the transformation I provided for ##\psi_{L,R}^{\dagger}## was wrong because of that. Now I think it should be OK.
Regarding 5.
$$\psi_{L,R}^{\dagger}\rightarrow e^{-i\alpha\gamma_5}\psi_{L,R}=\sum_{n=0}^\infty \frac{(-i \alpha \gamma_5)^n}{n!}\psi_{L,R} = \sum_{n=0}^\infty (\pm)^n \frac{(i \alpha)^n}{n!}\psi_{L,R} = e^{\pm i\alpha} \psi_{L,R}$$
We now apply the transformations we got to the Lagrangian (note that we can commute ##e^{+ i\alpha}## as we wish, because it is not a matrix anymore (EDIT: this is probably a wrong assumption and thus the reason why I am not getting the desired result; a hint would be appreciated if that is the case :) ).
$$\mathscr{L'} = i e^{+ i\alpha} \psi_{L} \gamma^0 \gamma^{\mu}\partial_{\mu}e^{- i\alpha}\psi_{L} + ie^{- i\alpha}\psi_{R} \gamma^0 \gamma^{\mu}\partial_{\mu}e^{+ i\alpha}\psi_{R}=i \psi_{L} \gamma^0 \gamma^{\mu}\partial_{\mu} \psi_{L} + i \psi_{R} \gamma^0 \gamma^{\mu}\partial_{\mu} \psi_{R}$$
Mmm... almost there!
I have to be missing something here; of course
$$i \psi_{L} \gamma^0 \gamma^{\mu}\partial_{\mu} \psi_{L} + i \psi_{R} \gamma^0 \gamma^{\mu}\partial_{\mu} \psi_{R} \neq i\psi_L^{\dagger} \gamma^0 \gamma^{\mu}\partial_{\mu}\psi_L + i\psi_R^{\dagger} \gamma^0 \gamma^{\mu}\partial_{\mu}\psi_R$$
Due to the fact
$$\psi_{L,R} \neq \psi_{L,R}^{\dagger}$$
  • #80
Yes that's essentially it. You don't get it 100% correct because you did an error in
Of course you forget a ##\dagger## everywhere here. Also you don't need to do the expansion again. You can simply do
$$\psi_{L,R}^\dagger \rightarrow (\psi_{L,R}')^\dagger=(e^{\mp i\alpha}\psi_{L,R})^\dagger=(e^{\mp i\alpha})^*\psi_{L,R}^\dagger=e^{\pm i\alpha}\psi_{L,R}^\dagger$$
Notice that now ##e^{\pm i\alpha}## it's a number, which simplifies our lives a lot. (That's the whole point of expressing everything in terms of ##\psi_{L,R}##, you could prove the transformation using ##\psi##, but it's much more complicated.)
Actually, notice that when working with Dirac sponsors, the Lagrangian is always written in terms of ##\bar{\psi}##, not ##\psi^\dagger##, so it's better for you to compute the transformation for ##\bar{\psi}_{L,R}## and then you can work always with this fields and you don't need to modify the Lagrangian.
Likes JD_PM
  • #81
Alright now let's prove that the Lagrangian is not invariant when ##m \neq 0##
$$\mathscr{L} = i\psi_L^{\dagger} \gamma^0 \gamma^{\mu}\partial_{\mu}\psi_L + i\psi_R^{\dagger} \gamma^0 \gamma^{\mu}\partial_{\mu}\psi_R - m\psi_L^{\dagger} \gamma^0 \psi_R - m\psi_R^{\dagger} \gamma^0 \psi_L $$
Applying the transformations
$$\mathscr{L'} = i e^{+ i\alpha}\psi_{L}^\dagger \gamma^0 \gamma^{\mu}\partial_{\mu} e^{- i\alpha}\psi_{L} + i e^{- i\alpha}\psi_{R}^\dagger\gamma^0 \gamma^{\mu}\partial_{\mu}e^{+ i\alpha}\psi_R - m e^{+ i\alpha}\psi_{L}^\dagger \gamma^0 e^{+ i\alpha}\psi_R - me^{- i\alpha}\psi_{R}^\dagger \gamma^0 e^{- i\alpha}\psi_{L}=i e^{+ i\alpha}\psi_{L}^\dagger \gamma^0 \gamma^{\mu}\partial_{\mu} e^{- i\alpha}\psi_{L} + i e^{- i\alpha}\psi_{R}^\dagger\gamma^0 \gamma^{\mu}\partial_{\mu}e^{+ i\alpha}\psi_R-m e^{2i\alpha} \psi_{L}^\dagger \gamma^0 \psi_R-m e^{-2i\alpha} \psi_{R}^\dagger \gamma^0 \psi_L \neq \mathscr{L}$$
QED 😍
  • #82
The exercise is almost done. Let's tackle c)
c) After solving a) b) you have all you need to show and explain that the ##m=0## Dirac-Lagrangian density ##\mathcal{L} = i \hbar c \bar{\psi_L}\gamma^{\mu} \partial_{\mu} \psi_L## describes zero-mass fermions with negative helicity only, and zero-mass antifermions with positive helicity only. (This field is called the Weyl field and can be used to describe the neutrinos in weak interactions in the approximation of zero mass).
But what are we supposed to explain and/or prove here besides what we've discussed so far?
  • #83
Well, the definition of helicity is defined (in Mandl & Shaw) in 4.47, but this a much more useful for us is the equation A.42. There you see that the helicity operator (for ##m=0##) is ##\gamma^5##. Therefore you have to prove that ##\psi_L## have negative helicity (is an eigenstate of ##\gamma^5## with eigenvalue -1) and that the antiparticle ##\bar{\psi}_L## is an eigenstate of positive helicity.
  • #84
Mmm I've been reading information regarding equation A.42 (page 457). Let me post it.
We define the operators related to the Dirac equation as follows:
$$\Pi^{\pm}( \mathbf p ) = \frac 1 2 (1 \pm \sigma_{\mathbf p})$$
Where ##\sigma_{\mathbf p}## is the ##4 \times 4## spin matrix.
For a zero-mass Dirac particle, we can express the helicity projection operators in terms of the ##\gamma^5## matrix. For ##m=0##, we have ##p_0=|\mathbf p|## and the spinors ##u_r(\mathbf p)## and ##v_r(\mathbf p)## satisfy the following equations (##r=1,2##)
$$\gamma^0|\mathbf p|u_r(\mathbf p)=-\gamma^k p_k u_r(\mathbf p)=\gamma^k p^k u_r(\mathbf p), \ \ \ \ \gamma^0|\mathbf p|v_r(\mathbf p)=-\gamma^k p_k v_r(\mathbf p)=\gamma^k p^k v_r(\mathbf p)$$
Multiplying ##\gamma^k p^k u_r(\mathbf p), \ \gamma^k p^k v_r(\mathbf p)## by ##\gamma^5 \gamma^0## on the left and using the identity ##\sigma^{i j} = - \gamma^0 \gamma^5 \gamma^k## we get
$$\gamma^5 u_r(\mathbf p)=\sigma_{\mathbf p}u_r(\mathbf p), \ \gamma^5 v_r(\mathbf p)=\sigma_{\mathbf p}v_r(\mathbf p) \ \ \ \ (A.42)$$
And the previously shown helicity projection operators become, for ##m=0##
$$\Pi^{\pm}( \mathbf p ) = \frac 1 2 (1 \pm \gamma^5) \ \ \ \ (A.43)$$
Do you mean I have to prove (A.43) out of (A.42)?
  • #85
Well, what you have to prove, as I said, is that ##\psi_L## and ##\bar{\psi}_L## are eigenstates of the helicity operator (so ##\gamma^5##).
Of course, it's best if you understand why ##\gamma^5## is the helicity operator when ##m=0## and, as in a lot of cases, a good exercise can be to see why ##\gamma^5## is NOT the helicity operator for massive particles. (So yes, you should prove all of the equations of section A.6)
Likes JD_PM
  • #86
Honestly, after reading section A.6, I still have no idea how could I do so.
Could you please give me a hint? I know I have to focus on (A.42) and (A.43) but I do not know how to move on...
  • #87
Well, just to have it clear, this exercise has two parts:
Part 1: Proof (or understand) why ##\gamma^5## is the helicity operator. This is a purely theoretical mathematical demonstration that has nothing to do with our exercise, is completely general and is what it's done in section A.6, if you want to discuss some of this theory, we can do that.
Part 2: Proof that our Lagrangian describes a particle of negative helicity. This is what we need to do for this example, which, from what we know is simply to prove that ##\psi_L## is an eigenstate of ##\gamma^5##. This has nothing to do with section A.6 and you will find no help there.
Likes JD_PM
  • #88
Thanks for the clarification.
I think we can assume by now part 1 and decide if we tackle it later and now go for part 2, which is what part c) is asking for. If you agree, could you please give me a hint on how I could approach Part 2?
Thank you.
  • #89
Well, you simply have to prove ##\gamma^5 \psi_L = -\psi_L## and ##\gamma^5\bar{\psi}_L^T=+\bar{\psi}_L^T##
  • #90
Let's prove ##\gamma^5 \psi_L = -\psi_L## (this was already proven at #62)
Is ##\gamma^5\bar{\psi}_L^T=+\bar{\psi}_L^T## meant to be equivalent to ##\gamma^5\psi_R=+\psi_R##? If yes, we also proved it at #62
  • #91
Well, you have to prove this and you are done
Likes JD_PM
  • #92
We have
$$\gamma^5\bar{\psi}_L^T=+\bar{\psi}_L^T$$
And we want to end up with
$$\gamma^5\psi_R=+\psi_R $$
We recall that
$$\psi_{L,R} := \frac{1 \mp \gamma^5}{2} \psi$$
$$\bar{\psi} := \psi^{\dagger}\gamma^0$$
$$\psi^{\dagger} := (\psi^*)^T$$
The LHS can be written as follows
$$\gamma^5\bar{\psi}_L^T=\gamma^5(\psi^{\dagger}_L\gamma^0)^T=\gamma^5 \Big( (\psi_L^*)^T\gamma^0\Big)^T= \gamma^5 \psi_L^* \gamma^0= \frac 1 2 \gamma^5 (1+\gamma^5)\psi \gamma^0=\gamma^5 \psi_R \gamma^0$$
Mmm but
$$\gamma^5 \psi_R \gamma^0 \neq \bar{\psi}_L^T$$
So one of the following assumptions I made has to be wrong:
1) ##(\gamma^0)^T= \gamma^0##
2) ##(\gamma^5)^* = -\gamma^5##
3) ##(\psi)^*=\psi##
  • #93
The same problem as always, in the third equality, ##\psi_L \gamma^0## makes no sense.
Also assumptions 2) and 3) are not true.
  • #94
Alright so the issue is that this equality doesn't hold
$$\gamma^5 \Big( (\psi_L^*)^T\gamma^0\Big)^T= \gamma^5 \psi_L^* \gamma^0$$
This is because the ##4 \times 1## matrix ##\psi## (contained in ##\psi_L^*##) cannot be multiplied by ##\gamma^0## (a ##4 \times 4## matrix).
So my mistake had to be made before reaching that equality. Do you agree? I still do not see it though...
  • #95
No, the LHS is correct, the problem is precisely this equality, I could tell you why is wrong, but I think would be more instructive that you try to show all the hidden steps and then write explicitly what properties are you using in each step.
Likes JD_PM
  • #96
I agree. You are doing right in not telling me what the solution is straight away.
Let's start over. This time I am going to use the fact that ##\bar{\psi}=\bar{\psi_L}+\bar{\psi_R}##
##\gamma^5\bar{\psi}_L^T=\gamma^5\Big(\bar{\psi}-\bar{\psi}_R \Big)^T=\gamma^5\Big(\psi^{\dagger} \gamma^0-\psi^{\dagger}_R \gamma^0 \Big)^T=\gamma^5\Big(\psi^{\dagger}\gamma^0-\frac 1 2 \psi^{\dagger} \gamma^0-\frac 1 2 \psi^{\dagger} \gamma^5 \gamma^0\Big)^T=\gamma^5\Big(\frac 1 2\psi^{\dagger}\gamma^0-\frac 1 2 \psi^{\dagger} \gamma^5 \gamma^0\Big)^T##
Do you agree? At point I think everything makes sense: before taking the transpose, inside the parenthesis we have ##1\times 4## matrices; once we take the transpose we get a ##4 \times 1## matrix. Thus the product ##\gamma^5(...)## is OK.
Mmm now the issue is to show that
$$\Big(\frac 1 2\psi^{\dagger}\gamma^0-\frac 1 2 \psi^{\dagger} \gamma^5 \gamma^0\Big)^T=\psi_R$$
Could you please give me a hint on how to do so?
