Getting weird formula for Capacitance
The discussion revolves around the formula for capacitance, C=Q/ΔV, and the confusion regarding the relationship between voltage and distance in a capacitor. The participants debate the application of electric fields from point charges versus the constant electric field in a parallel plate capacitor. It is clarified that the voltage in a capacitor can be determined using V=EΔd, where the electric field is constant. The conversation concludes with the understanding that to change the voltage in a capacitor, one must increase the charge, and the method for calculating voltage in a parallel plate capacitor is valid. The complexities of using point charge equations in this context are acknowledged as inappropriate.
lluke9
Okay, so I know
C=Q/ΔV
And ΔV is the sum of the electric fields multiplied by the distance between the charges, so if the first charge has a charge of Q and the other has -Q with R distance between, the electric potential/voltage is:
ΔV = [(kQ/r^2) + (kQ/r^2)]R
so
ΔV = 2kQ/R.
And C = Q/ΔV
so...
C = Q/(kQ/R)
and...
C = R/2k
and...
C = R/2[1/(4Πε_0)]
and
C = 2ΠRε_0
What...?
It would make some semblance of sense if R were inversely proportional to capacitance, but it isnt...
lluke9 said:
Okay, so I know
C=Q/ΔV
Where ΔV is the voltage between two conductors.
That's only true if the field is constant.
Not sure what you're doing here with two point charges.
In any case: In the expression for the field from a point charge, r is the distance from the charge. So r for one charge is different than the r for the other. Also, the field isn't constant, so you can't just multiply by the distance R.
Doc Al said:
Where ΔV is the voltage between two conductors.That's only true if the field is constant.Not sure what you're doing here with two point charges.
Well, I was just adding up the electric fields and doing V = EΔd...
But I'm guessing that's not possible because the electric field isn't constant...?
Okay, please forget about everything I typed up there, I guess it was a complete waste of time.So how DO you change the voltage in a capacitor? Wouldn't it be to just increase the charge?
Actually, how do you FIND the voltage in a capacitor? Is it V = EΔd, because the electric field is constant in a capacitor?
You charge a capacitor by hooking it up to voltage source (a battery, perhaps). The higher the voltage, the greater the charge stored on each conductor.
For a parallel plate capacitor, the field is constant. So you could use that method.
So could you substitute for voltage in the capacitance equation?
C = q/EΔd
Then E_T would be:
E_T = kq/r^2 + kq/r^2
because
E = kq/r^2
and both electric fields are going the same direction.
And then I'd arrive at the same thing I did in my original post...
E_T = net electric field
lluke9 said:
because
E = kq/r^2
That's the field for a point charge. Nothing to do with the constant field found between the plates of a parallel plate capacitor.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
