PeterDonis
Mentor
- 49,059
- 25,147
autoUFC said:So we have two possibilities.
1) you start alread in equilibrium when you remove the partition. Them you have no entropy increase. You may put the partion back and remain in equilibrium. In any moment you have extensivity.
2) you start out of equilibrium when you remove the partition. Them you have the partial preassures of each kind of gas to define the macroscopic state of each partition. Again, you have extensivity.
In the mixing scenario that has been under discussion throughout this entire thread, we are talking about 2). In your 1) above, the partial pressure of both gases must be the same on both sides of the partition, and that is not the initial condition we have been discussing. Of course if the gases are already mixed, you can insert and remove the partition as much as you like and it won't change anything--not entropy, and not the partial pressures of either gas. But that is not the scenario we have been discussing.
In the scenario we have been discussing, i.e., 2) above, the partial pressure of each gas is zero on one side of the partition, and positive on the other side. So yes, this partial pressure differential can be viewed as driving the mixing process. And, as I have said before, if you include a chemical potential term in your analysis (which here will include the partial pressure of each gas), you can keep track of the mixing process with it.
However, note carefully that, in case 2) as I have just described it, there is still mixing entropy. The process of mixing is still not reversible. And Jaynes' general point about all such cases still holds: in such cases it doesn't even make sense to talk about extensivity of entropy, because macroscopic variables are changing.
