Given charge of uniform density. What is the electrical potential @?
The problem involves calculating the electrical potential at the center of a circle with a uniform charge density of 4.50 nC/m. The correct formula for electric potential is V = kQ/r, where k is the Coulomb's constant. Initially, the user miscalculated by treating the charge density incorrectly, leading to an incorrect potential of 40.455V. The total charge was clarified as 4.50 nC/m multiplied by the circumference of the circle, resulting in a final potential of approximately 254V. The discussion highlights the importance of correctly interpreting charge density when calculating electric potential.
RedLego
Charge of uniform density 4.50nC/m is distributed along the circle of radius R. What is the electrical potential (relative to zero at infinity) at the centre of the circle?
Answer: 254V
electric potential: V=kQ/r
Because the charge of uniform density is 4.50 x 10^-9 C/m
I would assumed that would equal to Q/r, and all I need to do is multiply it by k, 8.99 x 10^9Nm^2/c^2.
V= (8.99 x 10^9)(4.50 x 10^-9) = 40.455V
Of course this is incorrect, tried searching it up on google, but failed. :(
If it's 4.50nC/m, what's the total charge, Q?
OHH! haha thanks i got it now :)
4.50nC/m * 2pi * k = 254.5V
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
