MHB Given sequences, finding the relation
The discussion revolves around comparing the sequences defined as \( a_n = (1^2 + 2^2 + \ldots + n^2)^n \) and \( b_n = n^n(n!)^2 \). The initial approach suggests rewriting \( a_n \) for easier comparison, but the user expresses uncertainty about the next steps. A suggestion is made to compare specific values, such as \( a_2 \) and \( b_2 \), to eliminate options regarding their relationship. Another participant proposes using the AM-GM inequality as a quicker method to determine the relationship between the sequences. Ultimately, the discussion highlights the complexity of comparing these sequences and the utility of mathematical inequalities in solving such problems.
Saitama
Problem:
Define $a_n=(1^2+2^2+ . . . +n^2)^n$ and $b_n=n^n(n!)^2$. Recall $n!$ is the product of the first n natural numbers. Then,
(A)$a_n < b_n$ for all $n > 1$
(B)$a_n > b_n$ for all $n > 1$
(C)$a_n = b_n$ for infinitely many n
(D)None of the above
Attempt:
The given sequence $a_n$ can be written as
$$a_n=\frac{n^n(n+1)^n(2n+1)^n}{6^n}$$
But I am not sure what to do now. I understand that this is a very less attempt towards the given problem but I really have no clue how someone should go about comparing these kind of sequences. Please give a few hints.
Any help is appreciated. Thanks!
Mathematics news on Phys.org
Start by comparing $$a_2$$ and $b_2$ this will eliminate one of the first two inequalities . Then proceed by induction.
Thanks ZaidAlyafey but I seem to have figured out a better solution. Use of AM-GM inequality gives the answer in a few seconds. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
