I Global coordinate chart on a 2-sphere
cianfa72
TL;DR Summary
Formal proof that it does not exist a global coordinate chart on a 2-sphere
Hi,
I know there is actually no way to set up a global coordinate chart on a 2-sphere (i.e. we cannot find a family of 2-parameter curves on a 2-sphere such that two nearby points on it have nearby coordinate values on ##\mathbb R^2## and the mapping is one-to-one).
So, from a formal mathematical point of view, how to prove it ? Just because there is not a (global) homeomorphism between the 2-sphere and the Euclidean plane ##\mathbb R^2## ? Thanks.
You could use the theorem of Borsuk-Ulam. It says that given a continuous function ##f:\mathbb{S}^2\rightarrow \mathbb{R}^2## there is always a point ##x\in \mathbb{S}^2## such ##f(x)=f(-x)## which makes bijectivity impossible.
Likes jbergman, dextercioby and cianfa72
ok, so the point is: take the 2-sphere ##\mathbb{S}^2## with an atlas. Define a global continuous function from ##\mathbb{S}^2## to ##\mathbb{R}^2##. In force of that theorem it cannot be bijective (one to one).
Yes. Simply take your chart ##\mathbb{S}^2\rightarrow \mathbb{R}^2## as ##f.## As ##f## cannot be injective, you will need at least two charts.
ok, honestly it seems to me an egg & chicken problem: to define a global function as continuous on ##\mathbb{S}^2## we actually need -- let me say "in advance" -- an atlas for ##\mathbb{S}^2##, don't you ?
I had an indirect proof in mind. Assume there is a ##1##-chart atlas, then Borsuk-Ulam leads to a contradiction. Hence, there must be at least two charts.
Two charts do the job. How would you prove it can't be less? (I mean the structure of a possible proof, not a proof itself.)
The sphere is compact! It cannot be homeomeprhpic to any open set in the plane.
Likes jbergman and WWGD
No, you do not need an atlas. You only need a topology.
I believe the contraddiction is as follows: suppose ##(\mathbb S^2, \phi)## is the 1-chart atlas. Take ##f= \phi##, then ##\phi^{-1} \circ f = I## hence ##f## globally defined is continuous by definition. It contraddicts that theorem since it is bijective by definition of global chart.
It can'be less since the contradiction above, no ?
Likes fresh_42
Surely, that was actually my point !
You had written it as a question why are they not homeomorphic. I just pointed out why: one is compact the other is not. Same reason why any compact manifold cannot be covered by a single chart.
ok, thank you. Now the next question could be: why two charts do the job ?
Because you can find two charts that do the job.
ok, so the proof of it is actually a "constructive" proof ?
You still have to prove compactness and its preservation under homeomorphisms. Compactness might be proven with Heine-Borel, which usually uses indirect parts, too.
Likes cianfa72
Stereographic projecton covers the whole sphere but a point. So two from different poles will do.
Likes cianfa72
Sorry for the stupid question: take a 2-sphere embedded in 3D euclidean space with cartesian coordinates ##(x,y,z)##.
Slice up the 2-sphere with planes ##x=const## and ##z=const## and assign coordinates ##(s,t)## to each of the resulting family of curves on the 2-sphere. This way each point of the 2-sphere should be mapped to just one ##(s,t)## tuple. Unlike the latitude/longitude coordinate system on the Earth there should be no singularity at all at the poles.
Does it actually make sense ?
Íf you consider ##\mathbb{S}^2## as manifold, and not as a subset of ##\mathbb{R}^3##, which is the subject here, then you do need an atlas, and the atlas defines the topology, not the other way round. This also makes compactness not evident.
What is your definition of a manifold? What is your definition of the two-sphere? In any case for a continuous map you only need topology, no additional structure.
Likes weirdoguy
https://ncatlab.org/nlab/show/manifold
Definitions 2.1. to 2.3.
Likes weirdoguy
What do you think about my post#17, is it really a one-to-one map ?
Maybe the problem is that even if it is one-to-one it is not (bi) continuous however (i.e. it is not a global homeomorphism)
Thank you.
If you slice with a plane ##x=const## you get a circle, same with ##z=const##. Those two circles can intersect at two points. In your construction those two points will have the same coordinates. For exanple ##x=0## and ##z=0## will intersect at the points ##(0,1,0)## and ##(0,-1,0)## so they have to have coordinates ##(s,t)=(0,0)##.
You're right, I was too sloppy :rolleyes:
For each circle on ##x=const## planes assign different ##s## coordinate values to each half-circle of it. To get a bijective map, points on the circle you get slicing the 2-sphere with the ##y=const## plane along the poles, belong to one alone of the two half-circles above.
Basically the ##t=const## coordinate lines are the latitude coordinate lines while the ##s=const## coordinate lines are akin to the longitude coordinate lines, however they do not result in a singularity at poles.
Any feedback about my last post ? Thanks
To me it is not clear what the map is. You just say pick different values, how? In any case what you end up with is not a chart, because the image is not an open set.
Let's try to visualize it in 3D space. Suppose the 2-sphere is placed in 3D such that the plane ##x=0## is tangent to it on the "left side". Then, starting from the left, for each half-circle on ##x=c , c>0## planes assign coordinate ##s=c## to one half-circle and ##s=-c## to the other (proceed this way up to the 2-sphere "right side").
As above I believe it should result in a one-to-one map, however as you pointed out the image on ##\mathbb R^2## should be not an open set in ##\mathbb R^2## standard topology.
The goal was try to build a one-to-one map for the 2-sphere. As we know, however, it can never be a (global) chart for it.
Make sense ? Thank you in advance.
Thank you.
But if it's not 1-1, its inverse is not even defined.
Why not ? In post #27 I specified better the map: for each point in ##\mathbb R^2## there is 0 or 1 point on the 2-sphere.
Have a look at the stereographic projection. That is how it is usually done.
  • #31
It seems to me it is not bijective because for example the North Pole is not mapped on any point of the plane. Mine was just a "proposal" of a bijective map on its image nevertheless it is not a (global) chart.
  • #32
Bijection is not hard if it is not continuous.
  • #33
So do you agree it is actually a bijection on its image ?
  • #34
Yes, that is the reason why we need two charts. One, if we allow infinity to be the image of the North Pole.
Likes cianfa72
  • #35
cianfa72 said:
Summary:: Formal proof that it does not exist a global coordinate chart on a 2-sphere
Hi,
Another route to prove this would be the following.
If there is a single chart for the 2-sphere then we could use that chart to define a non-vanishing vector field for every point on the sphere, i.e., just a vector in the direction of one of the coordinate axes.
We know this is impossible by the hairy ball theorem.
  • #36
So, from a formal mathematical point of view, how to prove it ? Just because there is not a (global) homeomorphism between the 2-sphere and the Euclidean plane ? Thanks.
the sphere is a compact set and a chart is not
  • #37
Just to add some detail to your claim. Suppose there is a single chart for the 2-sphere: we can use such chart to define a (one-chart) differentiable atlas for the 2-sphere (by definition a chart is compatible with itself).
Now, by definition, a vector field over the 2-sphere equipped with that 'one-chart atlas differentiable structure' is assigned through differentiable functions as its components. Take as non-vanishing vector field the vector field having the constant function 1 as the component in one of the coordinate axes and zero otherwise.
As you pointed out that is actually impossible for the 2-sphere by the hairy ball theorem.
  • #38
I haven't read the details but by Borsuk Up an, it is not possible.
