% glycolic acid needed to replace 40% phosphoric acid
  • Thread starter Thread starter Pastaking
    Acid
To determine the percentage of glycolic acid needed to replace 40% phosphoric acid by weight, the conversion from weight% to molarity is essential. The phosphoric acid's molarity is calculated to be 5.11 mol/L, considering its triprotic nature, which requires multiplying the molarity by 3 for the equivalent glycolic acid molarity. The discussion seeks clarification on the correct approach to find the necessary glycolic acid percentage, emphasizing the need for precise numerical values. Accurate calculations and conversions are crucial for achieving the desired replacement ratio. The thread highlights the importance of understanding acid properties in such conversions.
Pastaking
What is the % glycolic acid needed to replace 40% phosphoric acid (assuming it is weight%)?
I tried to solve this by first converting the Phosphoric acid weight% to mol/L for the phosphoric acid (5.11 mol/L)..
Since phosphoric acid is triprotic, I just multiply by 3 the calculated Molarity of phosphoric acid for the molarity of glycolic acid ... I am not sure if i did it right...how do we find the answer?
Need some numbers. Your numbers. Not mine.
That is all the numbers for the question...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
