I Going Up-Down Elevator G-forces vs Bouncing off a Spring G-force
  • I
  • Thread starter Thread starter ESponge2000
ESponge2000
TL;DR Summary
In GR terms,
Riding Up-down elevator … during de-acceleration relative to ground and acceleration up…
G force exceeds 1
The same change in velocity relative to ground but at the top of a tower is where G<1
In GR you’re always forced by earth out of your geodesic except if the de-acceleration at the top or acceleration down from the top is made the same as if the elevator fell off the track and was loose
But now with spring/trampoline im reading that the experience at the bottom differs
When “bungee jumping” or trampoline is it correct that the G force would not behave the same on the upward bouncing up due to how the spring stores potential energy or absorbs energy at compression ? Or is your motion up and down when supported by a spring medhanism the same as would be in the elevator motor?
Reading where?
And what does this all have to do with GR?
Sounds like you confused about some basic Newtonian mechanics.
Likes russ_watters
ESponge2000 said:
Ai Says
There's your problem. LLMs aren't good at physics.
A lift motor will usually be controlled to minimise discomfort to its passengers. If you bounce off a spring the force is what it is. So a lift will generally smoothly vary the force towards zero as it approaches a stop. A spring will not.
As A.T. says, this has nothing to do with GR.
Likes russ_watters and Dale
ESponge2000 said:
Ai Says ...
Read a physics book instead.
ESponge2000 said:
Ai Says
Ignore anything that AI says regarding physics. We are glad to help you understand valid sources, but AI is not a valid source at this time and it currently generates bad information far faster than we can correct it.
Thread closed.
ESponge2000 said:
Ai Says that....
And the forum rules say that "AI-generated text apps like ChatGPT are not valid sources."
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
