Grade 11 Heat Capacity question
A 0.20 kg lead shot heated to 90 degrees Celsius is dropped into 0.50 kg of water at 20 degrees Celsius, and the goal is to find the final equilibrium temperature. The heat transfer equation states that the heat lost by the lead equals the heat gained by the water. The correct formulation involves using (90 - T2) for the lead's temperature change, ensuring positive values. After solving the equation, the final equilibrium temperature is determined to be 20.8 degrees Celsius. The discussion emphasizes careful handling of temperature differences and maintaining the equality in the heat transfer equation.
Confuzed_one
a 0.20kg lead shot is heated to 90 degrees celsius and dropped into an ideal calorimeter containing 0.50kg of water initially at 20 degrees celsius. What is the final equilibrium temperature of the lead shot? The specific heat capacity of lead is 128 Joules/(kg degrees celsius) and the specific heat capacity of water is 4186Joules/(kg degrees Celsius)
Ml = 0.20
Cl = 128
Til = 90
Mw = 0.50
Cw = 4186
Tiw = 20
Q= mass x heat capacity x difference in temperature
Qabsorbed + Qreleased = 0
0.20 x 128 x (T2 - 90) + 0.50 x 4186 x(T2 - 20)
25.6 x (t2 -90) + 2093 x (T2-20)
I am completely stuck after this. I don't know what to do with the difference in temperature part. I've looked at example equations and it shows the temperature given getting transformed into joules? So in this equation the 90 and 20 would be replaced by different numbers with the unit Joules after. I don't understand why this is happening. Thank you for any help and I appreciate you taking the time to read this.
This may not be very clear, so if I need to explain more please let me know
Ml = 0.20
Cl = 128
Til = 90
Mw = 0.50
Cw = 4186
Tiw = 20
Make an equation out of it as in your Relevant Equations section. Solve for T2.
When units (Joules, °C, etc.) get confusing, take your equation and substitute each item with its corresponding units. Check how the units cancel and combine. They should all 'harmonize' to produce the expected units that are on the other side of the equation.
I tried rearranging it to solve for T2, but I'm definitely doing something wrong.
0.20 x 128 x (t2 - 90)
-T2 = 0.20 x 128 - 90
-t2 = 25.6 - 90
-t2 = -64.4
T2 = 64.4
This is one of those multiple choice answer things, and this isn't an option sadly. I understand the whole unit thing, I'm just pressed for time and trying to shorten it. I really appreciate the help thank you
EDIT: I realized i should factor this, so I did it and I got the correct answer of 20.8 degrees celsius. I know this is kind of random and I am not explaining myself, but you really helped and I got the right answer. Thank you very much, you have no idea how much i appreciate it
May I offer a little clarification at the beginning?
Heat lost by lead = heat gained by water
mC*ΔT = MC*ΔT
0.2*128*(90-T2) = .5*4186*(T2-20)
This differs from your solution in that there is an equals sign in the middle
and your (T2-90) is replaced by (90-T2). (T2-90) would be a negative number, leading to all sorts of trouble!
Next step is to expand both sides out so you only T2 terms and numerical terms.
Collect like terms and solve for T2.
Keep the = sign in every line!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
9K
