I Gradient descent algorithm and optimizers
  • I
  • Thread starter Thread starter fog37
    Minimum
The discussion centers on the gradient descent algorithm as a method for finding the minimum of a function by following the negative of its gradient. While gradient descent is effective, it has limitations, such as potentially getting stuck in local minima and requiring differentiability of the function. Alternative methods like Newton's method and Maximum Likelihood Estimation are mentioned, with a note that they may offer advantages in certain scenarios. The conversation also touches on gradient descent optimizers, which adaptively change the step size during the process. Overall, understanding these concepts is crucial for effective function optimization in various applications.
fog37
TL;DR Summary
understand what optimizers are in relation to the gradient descent algorithm
Hello,
To find the minimum (global or local) of a function, we can set the function's gradient equal to zero and solve for the $x$. This is the classic, analytic approach to find the minimum and it works if the function is differentiable and if it has not to many parameters (how many?)
An alternative is to setting the gradient equal to zero, is to still use the gradient of the function and the gradient descent method: to minimize the function, we follow the negative of the gradient and go in the direction of steepest descent. We start at a random $x$ value, set a step size, calculate the gradient at that $x$ value to calculate get a new $x$ value. We repeat the process (finding new x value and calculate the gradient there) until the gradient becomes equal to zero (or almost). I think that is correct...So far so good.
Q1: There are other iterative methods to find the minimum of a function. For example, Newton's method or the Maximum likelihood estimation. Why choose the gradient descent? What virtues does it have?
Q2:The gradient descent methods has limitations. We really want to find the "global" minimum but as soon as the gradient descent algorithm finds some point that is at a local minimum, it never escapes it. Are other iterative methods able to find the "global" minimum instead?
Also, the gradient descent only works if the function is differentiable everywhere. Are most real-life functions differentiable or not differentiable? The loss of function of neural networks may have millions of variables but are generally differentiable...
Q3: I have been reading about gradient descent "optimizers"...What are these optimizers? Are they variants of the gradient descent method where the step size is adaptive, i.e. it changes throughout the iterative process?
Thank you for any input!
Mathematics news on Phys.org
Hi,
For me this is the category 'impossible to answer'. Function optimization can fill a lifetime and more. Bookcases full of literature on the subject. The way you casually write
fog37 said:
TL;DR Summary: understand what optimizers are in relation to the gradient descent algorithm
We start at a random ##\bf x ## value, set a step size
lets me suspect you have no experience yet. So keep reading !
Perhaps you can narrow things down a bit ? And
fog37 said:
I have been reading
is good. But with a reference it gets a little bit better.
fog37 said:
if it has not too many parameters (how many?)
Depends on the function. In process simulation (chemical engineering) ##10^5## variables isn't outrageous (Speedup, gPROMS). Oh, and: #\LaTeX## in mathjax is to be enclosed in double # for in-line and in double $ for displayed math ##\ ##
Likes FactChecker
These are all good questions. The general subject is nonlinear programming, either constrained or unconstrained.
If the objective function has only one variable, but it is a high order, then even one variable can be difficult analytically.
There are tons of methods. Some use an analytically supplied gradient, some estimate the gradient based on the function values at certain points. You can not always assume that there is an analytical gradient. There are "pattern search" methods that will still work.
Yes. It is advisable to perform several optimizations beginning at different starting points. You have not mentioned constraints. Constraints can make corners in the feasible region that are dead ends and not nearly optimal.
You have also not mentioned any randomness in the function evaluation. There is a lot of randomness in the world. One approach is to start with a general, simple, overall shape of the objective function and use that to concentrate on certain areas in more detail (see response surface methodology).
That probably depends on the subject area.
Most iterative algorithms adjust the step size as they run.
IMO, one quick way to get an overview of the subject would be to look through the optimization sections of a good R-language or MATLAB reference and see what they are talking about.
Likes fog37 and BvU
Thing is, it's not just the number of variables that matter, but that it's difficult to find the zeros of gradient functions; often of functions in general. That's why you use methods such as gradient descent.
Likes fog37 and FactChecker
BvU said:
So keep reading !
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
