Gram-Schmidt procedure to find orthonormal basis
MellyC
The four functions v0 = 1; v1 = t; v2 = t^2; v3 = t^3 form a basis for the vector space of
polynomials of degree 3. Apply the Gram-Schmidt procedure to find an orthonormal basis with
respect to the inner product: < f ; g >= (1/2)\int 1-1 f(t)g(t) dt
ui = vi - \sumi-1j <vi, uj>/||vj||2> *vj
I am not sure that the impact that given inner product integral gives to the question. I don`t even know how to approach this question as well, because I have typically been given vectors of the form (x1, y1, z1) to use gram-schmidt orthonormalization with, not of the given form.
What is stopping you from using the formula in (2) with the inner product as defined in (1)?
RGV
How would I go about doing that? I'm a little bit confused about what the relationship between f(t), g(t), vi and ui is in this case. I understand that I can put the integral from part 1 into the inner product for the gram-schmidt orthogonalization in part 2, but what would my f(t) and g(t) represent?
They would be whatever two functions whose inner product you want.
RGV
Welcome to PF, MellyC! :smile:
Let's take the first two as examples:
u_0 = v_0
u_1 = v_1 - \sum_{j=0}^{1-1} {&lt;v_1, u_j&gt; \over ||v_j||^2} \cdot v_j
So:
u_0 = 1
u_1 = t - {&lt;t, 1&gt; \over ||1||^2} \cdot 1
with:
&lt;t, 1&gt; = {1 \over 2} \int_{-1}^1 t \cdot 1 dt
||1||^2 = &lt;1, 1&gt; = {1 \over 2} \int_{-1}^1 1 \cdot 1 dt
Can you calculate u1 from this?
And u2 and u3?
If you really want to, you can look at the polynomials like that. A polynomial f(t) is a linear combination of your given basis vectors:
f(t) = a_0 + a_1 t + a_2 t^2 + a_3 t^3 = a_0 \vec{v}_0 + a_1 \vec{v}_1 + a_2 \vec{v}_2 + a_3 \vec{v}_3so f(t) corresponds to the coordinate vector (a0, a1, a2, a3) and vice versa. You could do your calculations using the 4-tuples (except the inner product since it involves integrating the functions) and then convert your answers back to polynomial form.
But you should be able to see that scalar multiplication of a 4-tuple is the same thing as the usual scalar multiplication of the polynomial. Similarly, vector addition of the 4-tuples is the same as adding the two polynomials the way you normally do. So there's really no reason to use the 4-tuples instead of the polynomials directly in the calculations. They're just different ways of writing the same thing.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
