Graph Conic: Hyperbola - Key Features
  • Thread starter Thread starter aisha
    Graph
The equation provided represents a hyperbola, and to graph it, one should isolate either x or y for easier plotting. The standard form of a hyperbola is highlighted, indicating that the given equation needs to be multiplied by -1 and adjusted to fit this format. The center of the hyperbola is determined by the coordinates (a, b), and the vertices can be found by measuring distances from this center based on the values of u and v. Asymptotes can be drawn using the derived equations, which guide the shape of the hyperbola. For those seeking an easier method, software like Graphmatica can be used to graph the equation directly.
aisha
4(x+1)^2 - \frac {(y+2)^2} {9} = -1
I think this is the equation for a hyperbola, I don't know how to graph this and state the key features can someone please help me? :redface:
Try to isolate either x or y. That way, it will be easy for you to find the plotted points.
If, however, you have a program, like Geometer's Sketchpad, you can plot that graph without doing anything.
Quit flooding the board with repetitive questions, AISHA!
You are going a little overboard here, Aisha.
Do you know what the "standard" formula for ellipse, parabola, hyperbola look like? That should be in your textbook and your textbook should be your first resource.
Yes, this is a hyperbola- one of the first things you should have learned is that two squares with the same sign is an ellipse (considering a circle as a special case of an ellipse), two square with different signs is a hyperbola, one variable squared but not the other is a parabola (all assuming there is no "xy" term- you really don't want to deal with that!).
The standard form for a hyperbola is \frac{(x-a)^2}{u^2}- \frac{(y -b)^2}{v^2}= 1 or \frac{-(x-a)^2}{u^2}+ \frac{(y -b)^2}{v^2}= 1.
The form you have is almost that: you will need to multiply the equation by -1. Also that 4(x+1)^2 should be changed to \frac{(x+1)^2}{(\frac{1/2})^2}.
The center of such a hyperbola is at (a,b) (you knew that didn't you?). A good way to graph it is this- from (a,b) measure distance u to right and left and v up and down so you can draw the rectangle with center at (a,b), sides of length 2u and 2d.
Draw the diagonals. Those will be the asymptotes of the hyperbola, with equations
y= (v/u)(x- a)+ b and y= (-v/u)(x-a)+b. To determine the vertices, you will need to decide whether the axis of the hyperbola is vertical (x= a) or horizontal (y= b).
If x= a is the equation solvable for y? If so the axis is vertical (and the vertices are is at (a,b+v) and (a,b-v)), if not, the axis is horizontal (and the vertices are at (a+u,v) and (a-u,b)).
If your teacher allows, then download graphmatica. Its easy to use, and also freeware. it allows you to type in any equation and it produces the graph from straight lines to tricky conics to trigonometry.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
