Graphing question: Reversal of x and y axis & effect on slope and y-intercept
Reversing the x and y-axis on a linear graph maintains its linearity, resulting in a reflection along the line y=x. In the original equation, where y represents V^2 and x represents d, the slope is 2a and the y-intercept is Vi^2. Upon reversing the axes, the new equation becomes d = (V^2)(1/2a) - (Vi^2)/2a, indicating that the new slope is 1/2a and the new y-intercept is -Vi^2/2a. The transformation confirms that the graph remains linear despite the axis reversal. The solution provided aligns with the expected mathematical principles.
unigal13
How does the slope and y-intercept change if you reverse the x and y-axis of a linear graph. Will the graph still be linear?
The original y=mx+b format followed the physics equation:
V^2 = 2a(d) + Vi^2
Therefore, when y was "V^2" while x was "d", the y-intercept was Vi^2 and the slope was equal to "2a".
What are the y-int and slope once the axis are reversed, and x is "V^2" and y is "d"?
The attempt at a solution
I'm sure this is quite simple, but for some reason I am stumped. I realize the new graph would still be linear, reflected along y=x.
I tried inserting the new x and y values into the equation, getting:
x = my + b
(x - b)/m = y
(v^2 - vi^2)/2a = d
so (v^2)(1/2a) - (vi^2)/2a = d
leaves the new equation in the form of mx + b = y
with m = 1/2a
and b = (-vi^2)/2a
Have I come to the correct solution?
Thanks a lot!
No one can confirm my work?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
