Gravitation and potential energy
The discussion focuses on the gravitational effects of the moon on a spacecraft traveling from Earth to the moon, emphasizing the need to include the moon's gravitational potential energy in calculations. It outlines a problem involving the total gravitational potential energy of a particle influenced by both Earth and the moon, requiring the calculation of distances and forces. A specific point exists between the two bodies where the net gravitational force is zero, and the discussion seeks to determine the distance from Earth to this point. Additionally, it addresses the launch speed needed for a spacecraft to reach this equilibrium point and the impact speed when approaching the moon from an initial speed of 11.2 km/s. The conversation highlights the complexities involved in these gravitational calculations.
cuman12
In the example 12.5 (Section 12.3) in the textbook we ignored the gravitational effects of the moon on a spacecraft en route from the Earth to the moon. In fact, we must include the gravitational potential energy due to the moon as well. For this problem, you can ignore the motion of the Earth and moon.
A) If the moon of mass m(m) has radius R(M) and the distance between the centers of the Earth and the moon is R(EM), find the total gravitational potential energy of the particle-earth and particle-moon systems when a particle with mass m is between the Earth and the moon, and a distance r from the center of the earth. Take the gravitational potential energy to be zero when the objects are far from each other. Take the mass of Earth as m(E)
B) There is a point along a line between the Earth and the moon where the net gravitational force is zero. Use the expression derived in part (a) to find the distance of this point from the center of the earth.
C) With what speed must a spacecraft be launched from the surface of the Earth just barely to reach this point?
D) If a spacecraft were launched from the Earth's surface toward the moon with an initial speed of 11.2 {\rm km/s}, with what speed would it impact the moon?
Perhaps it would help if you would show where you encountered problems in your attempts to solve this problem?
It was in mastering physics
Try!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
