Gravitational Energy and Kepler's Law
In a double-star system with two stars of equal mass, the common angular speed can be determined using gravitational and centripetal force equations. The gravitational force acting on the stars provides the necessary centripetal force for their circular motion. The minimum speed required for a meteoroid to escape the system is calculated using the gravitational potential energy formula. The discussion highlights the importance of correctly applying the equations for gravitational force and centripetal acceleration to find the angular velocity and escape velocity. The calculations lead to a specific escape speed of approximately 2.24 x 10^4 m/s.
jetsfan101202
1. In a double-star system, two stars of mass 6.0 *10^30 kg each rotate about the system's center of mass at a radius of 2.0 * 10^11 m.
(a) What is their common angular speed?
(b) If a meteoroid passes through the system's center of mass perpendicular to their orbital plane, what minimum speed must it have at the center of mass if it is to escape to "infinity" from the two-star system?
F=-GMm/r^2
A=V^2/R
V(orbit)=sqrt(GM/r)
U(gravitational potential energy) = -GMm/R
I tried to do F=ma and a=v^2/r so m(v^2/r)=GMm/r^2
any help would be greatly appreciated. I need this done by midnight. thanks so much
Welcome to PF!
In all circular orbit problems, begin with the fact that the centripetal force is the gravitational force: Fc = Fg
Put in the two detailed formulas for the forces (with the mass and radius in them). Then you can solve for the velocity or period easily. And one more step to get the angular velocity.
isn't that what I did in my attempt at a solution? the only other thing I realize is that the force of gravity is 2r not r. so m(v^2/r)=GMm/(2r^2). Do I need two separate equations for both stars?
Sorry, jetsfan - I failed to see that you already had done what I suggested!
Now I don't understand why you are stalled.
You have v² = GM/(4r) so v = 2.24 x 10^4 m/s.
From there you can get ω = v/r in a moment . . . and you're done.
Oh, is it the wrong answer?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
