I Gravitational lensing of gravitational waves - real?
Al_
TL;DR Summary
Is gravitational lensing of gravitational waves a real thing? We hear discussion of the lensing of light, but would it also happen for gravitational waves? And how powerful could this be at it's strongest?
How powerful could this be at it's strongest, say, a supermassive black hole merger lensed by another nearby black hole?
Could the waves be powerful enough to be easily detected, or even to be seen directly if a human was there? What would they do to solid matter, bend or crack it?
Since gravitational lensing is a result of the intermediate mass determining what the geodesic paths are (straight lines, shortest distances in spacetime), I would expect it to influence all physical entities.
As far as detection goes, we would need great directional accuracy in measuring gravitational waves to see it. The angles from lensing of light that we have seen are very small.
Al_ said:
TL;DR Summary: Is gravitational lensing of gravitational waves a real thing? We hear discussion of the lensing of light, but would it also happen for gravitational waves? And how powerful could this be at it's strongest?
You can't expect the sort of image resolution that you get with optical wavelengths. Optical telescopes can image lensing rings of the angular size of a few square seconds of arc but the wavelengths of gravitational waves are long and the 'aperture' of detectors is small in wavelengths and the signal to noise ratio is low so the resulting resolution is no better than a few degrees and often a lot wider.
Likes FactChecker and phinds
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
