Gravitational potential energy question -- Ojbect sitting on the Earth
Gravitational potential energy is a property of the system comprising both the object and the Earth, not just the object alone. When considering the object as a single system, its potential energy does not change when it is dropped; instead, the energy transfer occurs due to the work done by Earth's gravity. The potential energy of the system changes when the Earth is moved away, indicating that potential energy is not solely associated with the object. The correct expression for energy conservation in this context includes both the object and the Earth, reflecting their interdependent relationship. Ultimately, the potential energy belongs to the Earth-object system, emphasizing the need for careful consideration when defining systems in physics.
Vash25
Good day,
If I consider my system to be an object and the earth, and the object is on the surface of the earth, then the system will have gravitational potential energy. Why couldn't I say that only the object (considering it as my system) has gravitational potential energy?
Thanks
We often say this as an short hand, when the object is much less massive than the Earth, so when it's released the potential energy of Earth & object goes almost exclusively into the object's kinetic energy.
Likes cianfa72 and Vash25
Leave the object where it is and move the Earth away. The object is unchanged but the potential energy changes. Therefore the potential energy does not belong to the object.
If you could say that, then you would be equally justified to say that the Earth (when considered as your system) will have the potential energy and not the object. So which is it that "has" the potential energy, the object or the Earth? The answer is neither, the potential energy belongs to the two-component Earth-object system. When the common potential energy changes, so does the kinetic energy of the system's components. The correct mechanical energy conservation to write in this case is (subscripts o = object and E = Earth) $$\Delta K_{\text{o}}+\Delta K_{\text{E}}+\Delta U_{\text{o+E}}=0.$$It's only because the Earth's vertical speed does not change noticeably over the time that the object falls, that we ignore the Earth's change in kinetic energy as commented by @A.T.
You can separate the two and consider the object as a single-component system, but you have to be careful of what you say and how. If you drop the object when it alone is your system, it does not lose potential energy and gain kinetic energy as sometimes is the claim. The dropped object gains kinetic energy because the Earth does positive work on it through the force of gravity. This positive work is equal to the loss of potential energy of the two-component system. To summarize, you can think of the transfer of energy to the object as taking place internally in the two-component system and externally in the single-component system.
  • Love
Likes cianfa72, Vash25, vanhees71 and 1 other person
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
