Gravitational Potential inside a mass
Gravitational potential exists inside a mass, such as 500 km deep within the Earth. While the gravitational field intensity can be calculated using the mass within a specific radius, the same method cannot be applied directly to calculate gravitational potential. For a uniform density sphere, the potential formula leads to incorrect force calculations due to the potential's non-uniqueness, as constants can be added without affecting the physics. The correct approach involves calculating the force first and then deriving the potential from that force. Understanding these concepts requires a solid grasp of the underlying principles of gravitational fields and potentials.
Knightycloud
I got an exam tomorrow and while i was studying, this popped in.
Is there a gravitational potential inside a mass (eg : 500 km deep from the Earth surface)?
We can calculate the Gravitational field intensity inside a mass by taking the distance from the center to that inner-point as x and calculating the mass within that radius; then taking that calculated mass into the G.I = -GM/x2
Can we do the same thing to calculate the potential? I googled and those graphs showed a similar behavior, we get as the potential inside a conductive sphere. Why can't us calculate it like that above method? I only understand GCE A/L by the way.
Of course.
No.
Consider a uniform density sphere. Use \Phi(r) = -GM(r)/r and take the gradient. This should yield the additive inverse of the force since \vec F(\vec r) = -\nabla \Phi(\vec r). However, since M(r)=4/3\pi \rho r^3 for a uniform density sphere, this Φ(r) yields F=+8/3\pi G \rho r \hat r. The sign is wrong and the magnitude is twice as large as it should be. The potential must yield F=-\partial \Phi(r)/\partial r = -4/3\pi G \rho r \hat r.
Likes 1 person
Potentials are not uniquely defined - you can always add a constant. That is fine if you just consider a single potential, but it ruins the approach to combine the potential for each depth in that way.
You can calculate the force, and based on this force you can calculate the potential - that approach works.
Likes 1 person
That makes sense. Because my level of knowledge is limited to the basic principles and i haven't used δf(x)/δx applications any where and that describes how few I know about this topic. :/
Thanks a lot for the support people.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
