I Gravitational potential of an ellipsoid
The discussion revolves around the derivation of the potential formula outside a homogeneous ellipsoid of density, as presented in Landau's work. The potential is expressed through an integral involving the ellipsoid's semi-axes and density, with specific conditions for the variable ##\xi##. A multipole expansion is utilized to express the potential at a point, incorporating the mass quadrupole tensor. There is a concern regarding the signs in the original formula, suggesting a possible error that aligns with discrepancies found in a referenced document. The conversation concludes with a verification of the derivation from a reputable source.
ergospherical
Education Advisor
Insights Author
There is a formula for the potential ##\varphi## outside of a homogenous ellipsoid of density ##\mu## in Landau\begin{align*}
\varphi = -\pi \mu abck \int_{\xi}^{\infty} \left(1- \dfrac{x^2}{a^2 + s} + \dfrac{y^2}{b^2 + s} + \dfrac{z^2}{c^2+s} \right) \frac{ds}{R_s} \ \ \ (1)
\end{align*}where ##R_s = \sqrt{(a^2+s)(b^2+s)(c^2+s)}## and ##\xi## satisfies ## \dfrac{x^2}{a^2 + \xi} + \dfrac{y^2}{b^2 + \xi} + \dfrac{z^2}{c^2+\xi} = 1##. How is this formula obtained?
So far I can only find an expression in the limit of ##r \gg a,b,c##. The mass quadrupole tensor is ##Q_{\alpha \beta} = \displaystyle{\int_{\mathcal{V}}} \mu(3x_{\alpha} x_{\beta} - r^2 \delta_{\alpha \beta}) dV## therefore the potential at a point ##\mathbf{r}## has a multipole expansion ##\varphi(\mathbf{r}) = - \dfrac{km}{r} + \dfrac{1}{6} Q_{\alpha \beta} \partial^2_{\alpha \beta} \dfrac{1}{r} + \mathrm{etc}##. Due to the axial symmetry, the matrix ##Q## can be brought to diagonal form by aligning the coordinate system with the principal axes and the non-zero components are\begin{align*}
Q_{xx} &= \mu \int_{\mathcal{V}} d^3 x (2x^2 - y^2 - z^2)\\
&= \mu abc \int_0^{2\pi} d\phi \int_0^{\pi} d\theta \int_0^1 dr\, r^4 ([2a^2 \cos^2{\phi} - b^2 \sin^2{\phi}]\sin^3{\theta} - c^2 \cos^2{\theta} \sin{\theta} ) \\
&= \dfrac{\mu abc}{5} \int_0^{2\pi} d\phi \int_0^{\pi} d\theta \, ([2a^2 \cos^2{\phi} - b^2 \sin^2{\phi}]\sin^3{\theta} - c^2 \cos^2{\theta} \sin{\theta} ) \\
&= \dfrac{2\mu abc}{15} \int_0^{2\pi} d\phi \, (4a^2 \cos^2{\phi} - 2b^2 \sin^2{\phi} - c^2 ) \\
&= \dfrac{4\pi \mu abc}{15} (2a^2 - b^2 - c^2 )
\end{align*}where the "spherical-like" coordinate transformations ##x = ar\sin{\theta} \cos{\phi}##, etc. map the ellipsoid into the unit sphere. Similarly ##Q_{yy} = \dfrac{4\pi \mu abc}{15} (2b^2 - a^2 - c^2 )## and ##Q_{zz} = \dfrac{4\pi \mu abc}{15} (2c^2 - a^2 - b^2 )##. Now\begin{align*}
\partial_{\beta} \dfrac{1}{r} &= - \dfrac{1}{r^2} \cdot \dfrac{1}{2r} \partial_{\beta} r^2 = -\dfrac{1}{2r^3} \partial_{\beta} (x_{\gamma} x_{\gamma}) = -\dfrac{x_{\beta}}{r^3} \\ \\
\implies \partial^2_{\alpha \beta} \dfrac{1}{r} &= -\partial_{\alpha} \dfrac{x_{\beta}}{r^3} = -\frac{1}{r^3} \delta_{\alpha \beta} + \frac{3x_{\alpha} x_{\beta}}{r^5} = \frac{3x_{\alpha} x_{\beta} - r^2 \delta_{\alpha \beta}}{r^5}
\end{align*}therefore ##\partial^2_{xx} \dfrac{1}{r} = \dfrac{2x^2 - y^2 -z^2}{r^5}## and etc. therefore \begin{align*}
\varphi(\mathbf{r}) &= -\dfrac{km}{r} + \dfrac{2\pi \mu abc}{45 r^5} \left\{ (2a^2 - b^2 - c^2 )(2x^2 - y^2 -z^2) + \mathrm{y \ \ first} + \mathrm{z \ \ first} \right\} \\
&= -\dfrac{km}{r} + \dfrac{2\pi \mu abc}{45 r^5} \left\{ 6(a^2 x^2 + y^2b^2 + c^2 z^2) -3((b^2+c^2)x^2 + (a^2+c^2)y^2 + (a^2+b^2)z^2) \right\}
\end{align*}I haven't checked yet if this is consistent with ##(1)## as ##r## gets very big, but I'm more interested to know how Landau derived the exact expression?
Likes LCSphysicist and vanhees71
Golly, that was fast! Looks like exactly it, thanks.
Is it possible that it should be (minus signs wrong in eq 1 from ergospherical):
## \varphi = -\pi \mu abc \int_{\xi}^{\infty} \left(1- \dfrac{x^2}{a^2 + s} - \dfrac{y^2}{b^2 + s} - \dfrac{z^2}{c^2+s} \right) \frac{ds}{R_s} ##
The same error is present in equation (72) the document from Stanford above, but not in equation (3).
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
