Gravitational question (spacecraft)
An unmanned spacecraft in a circular orbit around the moon at an altitude of 52.0 km experiences a speed decrease of 27.0 m/s due to a thruster malfunction. The discussion revolves around calculating the speed at which the spacecraft will crash into the lunar surface if no corrective action is taken. Participants highlight the importance of using accurate values for the mass and radius of the moon in calculations, as small discrepancies can lead to incorrect results. There is confusion regarding the initial velocity, with one participant mistakenly assuming it to be zero immediately after the thruster fired. Overall, the conversation emphasizes the need for precision in both calculations and input values to solve the problem correctly.
ccsmarty
An unmanned spacecraft is in a circular orbit around the moon, observing the lunar surface from an altitude of 52.0 km. To the dismay of scientists on earth, an electrical fault causes an on-board thruster to fire, decreasing the speed of the spacecraft by 27.0 m/s.
If nothing is done to correct its orbit, with what speed (in km/h) will the spacecraft crash into the lunar surface?
mass of moon = 7.36*10^22 kg
radius of moon = 1.7374*10^6 m
This is what I tried, but I got the wrong answer. Can someone please tell me what I did wrong.
Thanks in advance.
Can you justify why you did this?
GM/R^2 - vf^2/R = a
And later on, why is v0 = 0?
Well, the first equation I got when I asked an online tutor for help.
I made v0 = 0 because I thought that the instant after the thruster fired, the velocity would be zero.
I tried doing the problem a different way today and here's my work:
However, this did not yield the right answer :(.
Any help is greatly appreciated.
What you did the second time around looks right to me. only thing I'm concerned with is the exact numbers, and how accurate your result needs to be...
for example you used 1.74*10^6 instead of 1.7374*10^6 (what you had in your initial post)... and 7.35*10^22 instead of 7.36*10^22 (what you had in your initial post)
those online homework things are a little problematic...
essentially your work looks right to me.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
