I Gravitational wave effects on different materials
  • I
  • Thread starter Thread starter Andy DS
Gravitational waves induce differential effects on materials, with softer items like ripe tomatoes distorting more than rigid objects like iron balls. LIGO's design relies on free-moving mirrors to detect these waves, and while the mirrors are not rigidly mounted, their relative movement is crucial for measurement. The sensitivity of LIGO is not significantly enhanced by mounting it on a softer base, as the primary concern is to suppress ground vibrations rather than enhance detection. Current designs focus on maintaining rigidity to minimize noise interference from Earth. Future proposals include space-based detectors, which could further improve sensitivity by eliminating ground-related distortions.
Andy DS
TL;DR Summary
Do gravitational waves squash soft materials more than stiff ones?
Given that the Earth's gravity will distort, say, a soft fruit like a ripe tomato more than an iron ball, can we say gravitational waves from space have the same differential effects on these and other common earthly items.
Does LIGO experience the effects of gravitational waves due to the distortion of the planet, if so could it be made more sensitive by mounting it on a soft more conformable base.
Astronomy news on Phys.org
The gravitational wave will induce strains in the object, and its internal forces will dictate how it responds. So the result will depend on material stiffness, yes.
Gravitational wave detectors are essentially free-to-move mirrors and a device that measures the distance between them. They have zero rigidity, ideally. Earth-based detectors need extremely rigid casings and very carefully designed mirror mounts to avoid transmitting vibration from the Earth to the detector. That's not really about detection of gravitational waves, though, just about suppressing noise.
I believe rigid-bar detectors were once suggested, but the LIGO type is more sensitive.
OK, so the mirrors aren't rigidly mounted and their position will be perturbed relative to the ground by the passing waves.
The mirrors move relative to each other (or at least, the distance between them changes). The ground is (ideally) not relevant to the operation of the detector. In fact, there are proposals for space-based sensors where the mirrors are on separate satellites.
https://en.wikipedia.org/wiki/Laser_Interferometer_Space_Antenna
Likes FactChecker, ohwilleke and PeroK
Andy DS said:
TL;DR Summary: Do gravitational waves squash soft materials more than stiff ones?
https://www.ligo.caltech.edu/page/ligo-technology
Likes FactChecker, ohwilleke, Ibix and 1 other person
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
