Is the Yukawa Strong Nuclear Flux dependent on both gauge and radius?
  • Thread starter Thread starter Orion1
    Graviton Monopole
The discussion centers on the calculation of Yukawa Strong Nuclear Flux and its dependence on gauge and radius. Participants derive expressions for graviton flux through closed surfaces, emphasizing the use of spherical coordinates for integration due to symmetry. The key equations presented include the gravitic field strength and the resulting flux, which is shown to be dependent on both gauge coupling constant and radius. The final expressions for Yukawa flux indicate a distinct relationship compared to other fluxes governed by Maxwell's equations and Gauss' Law, which are solely dependent on gauge. The correctness of these equations and their implications for understanding gravitational and nuclear forces are debated.
Orion1
What is the solution for a static graviton flux monopole through a closed surface? :rolleyes:
Sphere surface area:
dA = 4 \pi r^2
\Phi_G = \oint G_g \cdot dA = \oint G_g \cdot (4 \pi r^2)
[/Color]
G_g is the gravitic field strength: (arbitrarily chosen symbol)
G_g
[/Color]
Are you talking about arbitrary closed surface or about sphere. If you are talking about sphere then it is quite simple:
First thing: Flux is \Phi=\oint_S \vec{G} \vec{dA}. Second thing \vec{dA} in spherical coordinates (which are most appropriate because problem has a spherical simmetry) is \vec{dA}=R^2\sin\theta d\phi d\theta\vec{e_r}. Integration is trivial because \vec{G}=\frac{\gamma m}{R^2}\vec{e_r}.
In case of arbitrary surface we have \oint_A \vec{G}\vec{dA'}=\int_V \nabla\vec{G}dV'=-\int_V \nabla^2{\phi_g}dV'=-\gamma m\int_V \nabla^2\frac{1}{|\vec{r}-\vec{r'}|} dV'=4\pi\gamma m\int_V \delta(\vec{r}-\vec{r'})dV'=4\pi\gamma m, where V is such that A=\partial V.
G_g = \frac{\gamma m}{r^2}
Gauss' Law for gravitation:
\Phi_g = - \left( \frac{\gamma m}{r^2} \right) (4 \pi r^2) = - 4 \pi \gamma m
\boxed{\Phi_g = - 4 \pi \gamma m}
\Phi_g = \oint_A \vec{G} \vec{dA} = - \oint_A \frac{\gamma m}{r^2} \vec{e_r} \cdot r^2 \sin \theta d\phi d\theta \vec{e_r} = - \gamma m \int_a^b \left[ \int_c^d \sin \theta d\phi \right] d\theta}
\boxed{\Phi_g = - \gamma m \int_a^b \left[ \int_c^d \sin \theta d\phi \right] d\theta}
[/Color]
First expression you wrote is meaningless. You should have some differential form under integration. Expression would be OK if you had integral sign removed. Third expression is OK but you didn't perform integration. You should integrate \theta in boundaries from 0 to \pi and \phi in boundaries from 0 to 2\pi.
\Phi_g = \oint_S \vec{G} \vec{dA} = - \int_0^{\pi} \left[ \int_0^{2 \pi} \frac{\gamma m}{r^2} \vec{e_r} \cdot r^2 \sin \theta d\phi \vec{e_r} \right] d\theta
- \int_0^{\pi} \left[ \int_0^{2 \pi} \frac{\gamma m}{r^2} \vec{e_r} \cdot r^2 \sin \theta d\phi \vec{e_r} \right] d\theta = - \gamma m \int_0^{\pi} \int_0^{2 \pi} \sin \theta d\phi d\theta = -2 \pi \gamma m \int_0^{\pi} \sin \theta d\theta
-2 \pi \gamma m \int_0^{\pi} \sin \theta d\theta = - 4 \pi \gamma m
[/Color]
These are my equations for Yukawa Flux.
g - gauge coupling constant
S_n - Yukawa strong nuclear field strength
Yukawa Strong Nuclear Flux:
S_n = - \frac{g}{e^{\frac{r}{r_0}} r^2}
\Phi_n = \oint_S S_n dA = - \int_0^{\pi} \left[ \int_0^{2 \pi} \frac{g}{ e^{\frac{r}{r_0}} r^2} \cdot r^2 \sin \theta d\phi \right] d\theta = - g \int_0^{\pi} \left[ \int_0^{2 \pi} \frac{\sin \theta}{e^{\frac{r}{r_0}}} d\phi \right] d\theta
- g \int_0^{\pi} \left[ \int_0^{2 \pi} \frac{\sin \theta}{e^{\frac{r}{r_0}}} d\phi \right] d\theta = - 2 \pi g \int_0^{\pi} \frac{\sin \theta}{e^{\frac{r}{r_0}}} d\theta = - \frac{4 \pi g}{e^{\frac{r}{r_0}}}
\boxed{\Phi_n = - \frac{4 \pi g}{e^{\frac{r}{r_0}}}}
However, every other flux through a closed surface, such as Maxwell's equations and Gauss' Law for gravitation is only dependent on gauge. This flux equation is dependent on both gauge and radius. Are these equations correct?
[/Color]
