Gravity and Magnetism (Beginner Question)
In summary: There is no such thing as 'free energy'. While those are both viable sources of energy, any use of them results in an increase of entropy.
Raza
203
Isn't Gravity and Magnetism free energy?
How does it follow the conservation of energy rule?
There is no such thing as 'free energy'. While those are both viable sources of energy, any use of them results in an increase of entropy. You can never extract as much as was available in the first place.
I know there is no such thing as free energy but where does the energy of gravity and magnetism come from?
Do you know the definition of "energy"? I assume you are thinking that an eternal force must be using energy. But a gravitational or magnetic force between two objects is not energy. Energy comes from moving up or down in a gravitational or magnetic field, and clearly that is conserved: whatever you get by moving one way you give back moving the other way.
So the Earth has been pulling moon close to itself for thousands of years without using any energy?
For simplicity, let's assume an ideal case: circular orbit with no frictional losses.
Although the Earth does pull the moon away from a straight-line inertial path, the moon in its circular orbit doesn't get closer to the earth.
The Earth pulling on the moon in a circular orbit (i.e. tangent to the radius) can be accomplished without using any additional energy because the force of pulling in this case is doing zero work.
In that system, tidal forces sap energy from the orbit to move the moon closer to the earth, and they are most certainly conservative of energy. All of the gravitational potential energy lost can be accounted for in tidal friction (which is lost to the universe as heat).
Is this what you are saying?
F=MA
Since there is no additional energy added to make it stay in it's place, a=0, so F=M(0) making F=0?
[tex]\Delta K \stackrel{work-energy}{=} W_{net} \stackrel{net\ work}{=} \int \vec F_{net} \cdot d\vec r[/tex]
Since [tex]\vec F_{net}[/tex] is always perpendicular to [tex]d\vec r[/tex] for a uniform circular orbit, the net work done is zero.
F=MA
So then you don't know what energy is, do you? Where is the term for energy in that equation? Energy (work) is w=FD (for gravitational potential energy, among other things).
Once again, force and energy are not the same thing.
Can you have force without energy?
I meant to use the W=FxD but I forgot.
if F=0, then i this eqn, W=FxD, W (energy) should equal to zero. right?
Yes, of course. They are completely different things. Can you have red without blood?
Yes...
Or you could consider a (slightly) more accurate description of the Moon's orbit, recognizing it as an elipse. Then it becomes appearant that the Moon does fall toward the Earth, and picks up speed as it falls, loosing potential energy while gaining kinetic. This higher speed causes the Moon to climb once again to a higher orbit, slowing down on the way up, and exchanging kinetic energy back into potential
The combination of [gain in altitude and loss of speed], and [loss of altitude and gain in speed] always brings the Moon back to where it started at the beginning of any cycle. The sum total of gains and losses is zero.
F is *not* equal to zero. there is a gravitational force acting on the object...
It's the distance D between the Earth and the moon that stays constant (Case 1), or that moves up and down in regular circles (Case 2).
In Case 1, delta_D = 0, so, W = 0. no work done.
In Case 2, D moves up one, and down one. Say there is a gain of 1 joule when it comes closer, and a loss of 1 joule when it goes back further... we're at the same distance as before. thus, delta_D = 0, and by that, W = 0.
so, is there any other force beside the Earth gravity that pull the moon away from Earth? Such as, the Sun?
Yes, every object in the universe has a gravitational effect on the moon- most of them negligible of course. I believe that the sun has a small but noticable effect on the moon. Jupiter, the largest of the planets, other planets, and non-solar system objects have no measurable effect on the moon.
The quick answer to the original question about "free energy" from gravity and magnetism is: gravity and magnetism are not "energy", they are forces. There is no "conservation of force" law.
Thank you all for filling my curiosity. :)
FAQ: Gravity and Magnetism (Beginner Question)
What is gravity?
Gravity is the natural force by which objects with mass are attracted to one another. It is what keeps us grounded on Earth and what keeps planets in orbit around the sun.
How does gravity work?
Gravity works through the curvature of space and time, as theorized by Albert Einstein's theory of general relativity. Objects with mass cause a distortion in space-time, creating a gravitational pull towards them.
What is magnetism?
Magnetism is a force created by the movement of electrons. It is a fundamental force of nature, just like gravity, and it is responsible for the behavior of magnets and the interactions between electrically charged particles.
What is the difference between gravity and magnetism?
The main difference between gravity and magnetism is that gravity is a force created by the presence of mass, while magnetism is a force created by the movement of electrons. Gravity affects all objects, while magnetism only affects objects with electrically charged particles.
How do gravity and magnetism interact?
Gravity and magnetism do not directly interact with each other. However, they both play a role in the behavior of objects in space. For example, the Earth's magnetic field is influenced by the rotation of the planet, which is affected by gravity. Also, the sun's magnetic field can cause disturbances in Earth's atmosphere, which can affect our weather patterns.
9K
