Gravity and Permanent Magnetism as energy sources
In summary, the conversation discusses the possibility of creating a perpetual motion machine using a material that can disrupt the magnetic lines of force between two magnets, allowing gravity to provide the second source of energy. However, this concept has been proven to be impossible and has been the basis for many frauds. The conversation also mentions the development of new materials and the potential for breakthroughs in theoretical physics.
exwso2001
I'm an IT person - non-scientist - but this problem has challenged me ever since high school physics:
If two permanent magnets - pole to like pole - repel each other, the magnet suspended possesses potential energy. If a material can be found (that is non-magnetic and without any power source) that can disrupt the magnetic lines of force between the two magnets to where the magnets' separation decreases, then gravity would be providing the second source of energy (kinetic energy). You would basically have a new form of motor. Would it really be considered a perpetual motion device since gravitity and magnetism are both supplying energy?
It seems like new materials are being developed everyday. I just read about pyrolytic carbon and diamagnetism. Has something (not yet tried) been developed recently that can address this question? Is it just not feasible?
Similarly if a material could be found that blocked gravity you could make a perpetual motion machine with a pulley. That rather suggests such a material is impossible.
ps. This thread will get locked now, we don't allow discussion of perpetual motion machines since it tends to bring out the cranks.
Nothing personal and please don't feel got-at!
No offense. Like I said I'm no scientist. I just read about frogs suspended in strong magnetic fields and superconductivity where a current can last nearly forever, and wondered - No one would have believed these events possible in the past - so what else is possible. Einstien mentioned it's impossible to go faster than the speed of light, but it doesn't stop people from trying to find ways to do it. Science is always full of new surprises.
Charlie
Since nobody has locked it yet ...
Magnets are weird (even to people who are supposed to understand them) so are a prime topic of crackpottery, gyroscopes are the other!
Suspending a frog above a magnet is the same as suspending a frog on a shelf, you put the energy in by lifting it up there - there is no magnet energy holding it.
The frog doesn't spin naturally you have to give it a nudge.
Actually the frog on a magnet is breakthrough in theoretical physics - it was calculated 150years ago that you couldn't do it without spinning the frog (it would fall out of the field) then it was actually tried and you can do it with a stationary frog. It turns out the moving charges inside the fluids inside a frog are enough, this led to a bunch of new discoveries!
This is a common misconception (as mgb_phys points out) that has been the basis of many perpetual motion machines. A fellow named Richard Willis was hawking his machine on the CBC Dragon's Den program and a dragon (Brett Wilson, originally an engineer!) actually offered him a million dollars for it if it worked. No chance he will lose his million. See http://www.cbc.ca/dragonsden/pitches/magnacoasters.html".
The http://pesn.com/2007/02/18/9500457_Perendev_update/" is the classic case. It is a similar fraud. The principle is just as you described - he has a device that shields magnetism. The problem is that you cannot block magnetic field without using energy. Anyone who tells you otherwise is a fraud or a fool or both. Many people have lost a lot of money investing in this motor.
AM
Welcome to the PF, exwso2001. Discussions about perpetual motion machines are not permitted here, so I'm going to have to lock this thread. Hope your questions were answered.
Related to Gravity and Permanent Magnetism as energy sources
1. What is gravity and how can it be used as an energy source?
Gravity is a fundamental force of attraction between objects with mass. It can be harnessed as an energy source through technologies like hydroelectricity, where the force of gravity is used to turn turbines and generate electricity.
2. Can permanent magnets be used as a renewable energy source?
Yes, permanent magnets can be used as a renewable energy source. They can be used in magnetic generators to produce electricity without the need for any external energy source. However, the magnets themselves do not produce energy, but rather convert kinetic energy into electrical energy.
3. How efficient is using gravity or permanent magnetism as an energy source?
The efficiency of using these energy sources can vary depending on the specific technology being used. Generally, hydroelectricity has an efficiency of around 90%, while magnetic generators have an efficiency of around 70-90%.
4. Are there any limitations to using gravity or permanent magnetism as energy sources?
One limitation of using gravity as an energy source is that it requires a significant amount of infrastructure, such as dams and turbines, to harness its power. Additionally, the availability of suitable locations for hydroelectricity is limited. For permanent magnetism, the main limitation is the initial cost of the magnets and the need for regular maintenance.
5. How can gravity and permanent magnetism be used together as energy sources?
Currently, there are no technologies that combine gravity and permanent magnetism as energy sources. However, there are ongoing research and development efforts to explore the potential of combining these two forces to create more efficient and sustainable energy sources.
9K
13K
12K
