Gravity around small black holes
A black hole with a mass similar to the Sun would have a significant gravitational influence, creating distorted gravity fields that could affect nearby orbiting bodies. The stable orbits around such a black hole would be determined by its spin, with the lowest stable orbit at approximately 9 kilometers for a non-rotating black hole. Relativistic effects become pronounced within about 100 kilometers of the black hole, unlike the Sun, which has a much larger size and different gravitational dynamics. The lowest circular orbit, where light can orbit, is around 4.5 kilometers, with anything closer either falling in or escaping. Understanding these dynamics is crucial for studying the behavior of matter near black holes.
Paul Katan
If a black hole had a mass similar to the Sun (I know black holes tend to be at least three times larger but let's assume an unusual series of events) how far would the are of extremely distorted bent gravity around it be could it cause closely orbiting bodies to be pulled or pushed out of orbit around the black hole?
Astronomy news on Phys.org
A black hole has stable orbits around it in the same way all other objects have them. Even better: sun is a bit oblate due to its rotation, which has a notable influence on the perihelion precession of Mercury for example. A black hole is much smaller, so this effect gets much smaller as well.
Relativistic effects become strong very close to the black hole - for 1 solar mass, for distances below ~100 km. There are no orbits around the sun at that distance because sun is much larger, obviously. The lowest stable orbit depends on the spin of the black hole. If it is not rotating, the lowest stable orbit has a radius of about 9 kilometers. The lowest circular orbit is at about 4.5 kilometers (light can orbit here), and everything below that either falls into the black hole or escapes directly.
Note that "radius" is not a trivial concept close to a black hole.
Thanks
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
