t_siva03 said:
since the sun and Earth are in constant motion and their relative distance changes minutely by the minute, the Lagrange points should be consistently shifting, shouldn't they?
That's correct. Suppose a planet is
exactly in a circular orbit around a star and that this star has no other planets. Suppose a (small) object is placed
exactly at one of the libration points and is moving
exactly in sync with the motion of the libration point. The combined gravitational forces on the object coupled with the motion of the object will keep the object
exactly in sync with the libration point, forever. The key word here is "
exactly". What happens if the object is not
exactly at the libration point and moving with the libration point? My response below to Nabeshin addresses this question.
Because the planet is following a curved path, the libration points are also following curved paths. In order for an object to follow a curved path, there must be some force acting on the object. It is precisely because gravitational forces
do not cancel at the L1 point that an object exactly at the L1 point and moving exactly with the L1 point will follow the L1 point exactly.
What about the point where the gravitational forces truly do cancel one another? That point, like the L1 point, follows a curved path. An object placed at this cancelation point and instantaneously moving with the cancelation point would just move in a straight line (initially). Think of it in terms of Newton's first law. Meanwhile this null gravity point will curve off away from the object. The point where the gravitational forces cancel is rather uninteresting and is not very useful.
Nabeshin said:
It is also worth noting that the equilibrium point between the earth-moon, sun-earth, or any two body system is an unstable equilibrium. If there is even a small perturbation the object will fall towards either of the gravitating bodies, so I wouldn't expect to find anything there.
The collinear libration points (L1, L2, and L3) are indeed metastable (metastable = unstable equilibrium, such as a ball balanced on top of another ball). What metastable means is that
any deviation from the equilibrium state will grow and grow. Compare to a stable equilibrium point, where sufficiently small deviations from the equilibrium state become smaller or remain bounded.
Objects can be maintained at or near a metastable point with the application of external force. Example: An inverted pendulum. Put a broom with the business end up and the other end in the palm of your hand. You can keep the broom balanced by moving your hand about appropriately.
An object could similarly be maintained at one of the collinear libration points, but doing so would require a lot of energy. However, there exist pseudo-orbits about these points that, while still unstable, require significantly less expenditure of energy to maintain the orbit than would be needed to stay at the point.
The world's space agencies take advantage of these orbits because the Earth-Sun L1 and L2 points are very, very useful as locations for spacecraft . Three satellites are presently operating in pseudo-orbits about the Sun-Earth L1 point: SOHO, ACE, and Wind; WMAP operates about the Sun-Earth L2 point.
