Gravity of a Ring on a Particle
The discussion focuses on calculating the gravitational potential energy (U) of a particle near a ring-shaped body. The initial attempt at the solution incorrectly used the wrong formula, leading to confusion about the distance variables involved. The correct expression for U involves a positive addition in the denominator, which was a key point of misunderstanding. Participants emphasized the importance of correctly identifying the variables and their relationships, particularly the distinction between the radius and the distance from the mass. Ultimately, the individual seeking help acknowledged their errors and expressed gratitude for the clarification.
student34
Consider a ring-shaped body in a fixed position with mass M. A particle with mass m is placed at a distance x from the center of the ring and perpendicular to its plane. Calculate the gravitational potential energy U of the system (the picture has a small sphere traveling towards the center of a ring perpendicular to the ring's plane).
Fg = (G*m*M)/r^2
Fg*r = U = (G*m*M)/r, where r is the radius, and G = 6.67*10^(-11) (gravitational constant)
Let r be the hypotenuse of a right triangular distance to any part of the ring and a be the distance from the center of the ring to join the hypotenuse. x will make the 90° angle with a.
So, I thought that I would multiply the perpendicular component of force to the perpendicular distance x to get a function for gravitational potential energy,
F(perpendicular component) = (G*m*M)/(x^2) = (G*m*M)/(r^2 - a^2), where x^2 = r^2 - a^2.
Then, U = (G*m*M)/(r^2 - a^2)*(r^2 - a^2)^(1/2) = (G*m*M)/(r^2 - a^2)^(1/2).
But apparently this is wrong.
The right answer is U = (G*m*M)/(r^2 + a^2)^(1/2), the same as my answer except for the +.
I just don't understand why my answer is not right.
Provide picture please.
Are you positive that that is the correct answer?
Each section of the ring has some infinitesimal mass that is proportional to some infinitesimal length. Mathematically,
dM = \frac{M}{2πa}dl\\<br /> dM = \frac{M}{2πa}adø
If this substitution is not obvious to you, all I did was say that the infinitesimal length, dl, is actually an arc length, that, with a little bit of trig, can be given as L = aø. where ø is in radians, and is the angle that is swept out by the ring, and a is the radius. This obviously is 2pi for the entire ring, but we will come back to that. We can plug this infinitesimal mass into our potential energy problem and should see that for each tiny bit of mass, we should get a tiny bit of potentially energy.
Can you see where you need to go from here? I don't know what your physical level is, or what mathematical background you come from.
Oh thank-you so much! :)
Dear 34,
You want to consider where your relevant equations apply. You confuse me (and likely yourself as well) by using the term radius to describe r.
Then in your solution you use x (which is smaller than the distance between m and M -- meaning you would get a larger magnitude for the force). Why ?
There is another issue: your expression goes to infinity when x -> 0 which should go against all intuition.
[edit]So where did you end up with your answer ? And: is your r the same r as the r in the answer ?
BvU said:
Dear 34,
Yeah, I was out of control with this one; I get it now though. Thanks anyways!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
