Gravity Questions: Position & Velocity Equations
  • Thread starter Thread starter homeworkboy
    Gravity
When two identical balls are dropped from rest at different times, the distance between them initially increases but eventually remains constant after the second ball is dropped. The first ball accelerates due to gravity, while the second ball, dropped later, starts from rest and accelerates as well. The general equations for position and velocity under constant acceleration are essential for understanding their motion. The distance between the balls can be calculated using the formula for free fall, which considers gravitational acceleration. Familiarity with these equations is crucial for solving related physics problems.
homeworkboy
1. Two identical balls are dropped from rest, one at t=0, and the other a second later. Does the distance between them increase, decrease or remain the same.? Explain.
2. Write the general equations, in one dimension, for position and velocity of an object which experiences a constant acceleration.
Someone please help..i have no idea how to answer this. Thanks
Do you know how to do #2?
For #1, just think about it. In between t=0 and t=1, will the balls be getting farther apart? After t=1, will the balls have identical velocity?
no they will not have identical velocities. so yea they will be the same distance between them. I don't know 2,
Are you sure? What is the formula for distance of free fall in a gravity field? At the 3 second mark how far are they apart. At the 5 second mark how far apart are they?
i don't know wat formula ur tokin abt
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
