MHB *gre.al.9 GRE Exam Inequality with modulus or absolute value
The discussion focuses on solving the inequality |y+3| ≤ 4, leading to the conclusion that -7 ≤ y ≤ 1. Participants clarify that this does not assume y is positive, as the solution encompasses both negative and positive values of y. The breakdown of the absolute value into two cases—one for when y+3 is non-negative and one for when it is negative—illustrates the correct approach to solving the inequality. The final interval indicates that y can take on values from -7 to 1, confirming the range of possible signs for y. Understanding the definition and properties of absolute values is crucial in this context.
karush
MHB
given
$|y+3|\le 4$
we don't know if y is plus or negative so
$y+3\le 4 \Rightarrow y\le 1$
and
$-(y+3)\le 4$
reverse the inequality
$ y+3 \ge -4$
then isolate y
$y \ge -7$
the interval is
$-7 \le y \le 1$
Mathematics news on Phys.org
$|y+3| \le 4 \implies -4 \le y+3 \le 4 \implies -7 \le y \le 1$
That was quick..
Doesn't that assume y is positive
karush said:
That was quick..
what does the inequality, ${\color{red}-7 \le y} \le 1$, tell you about the possible signs for $y$?
also, see attached graph ...
definition of absolute value ...
$|\text{whatever}| = \left\{\begin{matrix}
\text{whatever}, & \text{if whatever}\ge 0\\
-(\text{whatever}), & \text{if whatever}< 0
\end{matrix}\right.$
therefore ...
$|y+3| = \left\{\begin{matrix}
y+3 \, , &\text{if }y+3 \ge 0 \\
-(y+3) & \text{if }y+3<0
$|y+3| \le 4$
case 1, $y+3 \ge 0$
$y+3 \le 4 \implies y \le 1$
case 2, $y+3 < 0$
$-(y+3) \le 4 \implies y+3 \ge -4 \implies y \ge -7$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
