Screwdriver
- 129
I'm teaching myself the Green's function method for ODEs, because it looks relevant to my interests. This is a (slightly contrived) problem I just came up with arbitrarily:
[tex]y''+5y'+6y=sin(x) \; \; \; ; \; \; \; y(0)=y'(0)=0[/tex]
i) When considered as a function of [itex]x[/itex] alone, [itex]G(x, z)[/itex] must obey the homogeneous initial conditions.
ii) The derivatives of [itex]G(x, z)[/itex] with respect to [itex]x[/itex] up to order [itex]n - 2[/itex] are continuous at [itex]x = z[/itex], but the [itex](n - 1)^{th}[/itex] order derivative has a discontinuity of [itex]\large{\frac{1}{a_{n}(z)}}[/itex] at this point.
Proceeding with the complementary solution (following the procedure outlined in my text):
[tex]G(x, z)=\left\{\begin{matrix}
A(z)e^{-2x} + B(z)e^{-3x}\Rightarrow & x<z \\
C(z)e^{-2x} + D(z)e^{-3x}\Rightarrow & x>z
\end{matrix}\right.[/tex]
We require [itex]G(0, z) = G'(0, z) = 0[/itex]. For some reason this implies [itex]A(z) = B(z) = 0[/itex]. I mean, it's obvious that this is true if [itex]G(x, z) = A(z)e^{-2x} + B(z)e^{-3z}[/itex], but it's a piecewise function, so why do we only consider [itex]x < z [/itex]?
Anyways, this equation is of order 2, so we need the 0th order derivative to be continuous. Also, the 1st derivative needs to have a discontinuity of 1 (because the leading coefficient is 1):
[tex]\begin{matrix}
C(z)e^{-2z}+D(z)e^{-3z}=0\\ -2C(z)e^{-2z}-3D(z)e^{-3z}=1
\end{matrix}[/tex]
Solving gives [itex]C(z) = e^{2z}, D(z) = -e^{3z}[/itex]. Then:
[tex]y(x) = \int_{0}^{\infty }G(x,z)sin(z)dz [/tex]
[tex]y(x)=\int_{0}^{x }[e^{2z-2x}-e^{3z-3x}]sin(z)dz[/tex]
[tex]y(x)=\frac{1}{10}(e^{-3x} (2e^{x}-1) - cos(x) + sin(x)) \leftarrow \text{Lazily computed with Mathematica.}[/tex]
What I don't get is why that improper integral all of a sudden changed to have limits from 0 to [itex]x[/itex]. Furthermore, why is it even an improper integral at all? I suspect that it's because the initial conditions don't specify a boundary, but then why shouldn't the lower limit be negative infinity?
Thanks so much, and sorry about the wall of Tex
