Grid connected transistor bridge inverter
In summary, the conversation discusses the use of a transistor-bridge converter to connect a PV array to the grid. The components are assumed to be ideal and lossless, and bipolar switching is used. The goal is to calculate the magnitude and angle of the fundamental voltage (Vi) generated by the converter. The method provided involves using the modulation index and DC voltage to find the peak voltage, then converting to RMS and using the sine rule to determine the total length of the phasor at a 15 degree angle to the grid voltage. This method is confirmed as correct by the professor.
Samtheguy
Hi there. I was just wondering if anyone can conform that my method for this problem is correct so far?
The transistor-bridge converter shown below is being used to connect a PV array to the grid.
For the purpose of this coursework, you may assume that:
• The PV array behaves as an ideal DC voltage source.
• The grid is an ideal sinusoidal voltage source at 50 Hz.
• The components are ideal and lossless.
• Bipolar switching is used.
The DC voltage (Vdc) is 458 V.
The inverter switches at 1800 Hz and its output inductor is 4 mH.
The modulation index is 0.59 at angle of 15 degrees relative to the grid voltage.
The AC grid voltage is 217 V.
Question - Calculate Vi (Magnitude and angle)
The modulation index is defined as: Mi = Vi peak (of the fundamental component) / Vdc
Therefore; Vi = Mi x Vdc
Vi = 0.59 x 458
Vi = 270.22V
However this is a peak voltage. Hence the rms voltage is; 270.22/sqrt(2)
So Vi = 191.074 V (rms)
Since it is at an angle of 15 degrees to the grid voltage, use the sine rule to obtain the total length of the Vi phasor.
Vi / sin(90) = 191.074 / sin(75)
Vi = 197.814V
So we'll say Vi = 198V at an angle of 15 degrees to the grid voltage.
Is that correct??
Looks right to me. I assume Vi is the square-wave voltage on the left-hand side of the inductor.
Hi and thanks for your reply.
My professor has since confirmed that this method is correct. Vi is the fundamental voltage of the waveform generated by the transistor bridge. The Vi waveform is a square wave where the pulse width changes in relation to the reference sine wave but frequency remains pretty constant. Fourier analysis shows that the fundamental component of the voltage is 50Hz with an amplitude related to the modulation index and the input dc voltage.
Related to Grid connected transistor bridge inverter
1. What is a grid connected transistor bridge inverter?
A grid connected transistor bridge inverter is a type of inverter that converts direct current (DC) power from a renewable energy source such as solar panels or wind turbines into alternating current (AC) power that can be fed into the grid. It consists of a bridge circuit of transistors that switches the DC power on and off at a high frequency, which is then transformed into AC power by a transformer.
2. How does a grid connected transistor bridge inverter work?
The grid connected transistor bridge inverter works by using a series of transistors to switch the DC power on and off very quickly. This creates a series of pulses that are then transformed into AC power by a transformer. The inverter also includes control circuits that monitor the grid voltage and adjust the output accordingly to ensure the power is fed into the grid at the correct frequency and voltage.
3. What are the advantages of a grid connected transistor bridge inverter?
There are several advantages to using a grid connected transistor bridge inverter. Firstly, it allows for the integration of renewable energy sources into the grid, which can help reduce the reliance on fossil fuels. Additionally, the inverter can help stabilize the grid by adjusting the output to match the grid voltage and frequency. It also has a high efficiency, meaning that it can convert a high percentage of the DC power into usable AC power.
4. What are the potential challenges of using a grid connected transistor bridge inverter?
One potential challenge of using a grid connected transistor bridge inverter is the need for proper synchronization with the grid. If the inverter is not properly synchronized, it can cause issues with the grid, such as voltage fluctuations or harmonics. The inverter also needs to meet certain technical requirements and safety standards to ensure it does not cause any harm to the grid or connected devices.
5. How is the performance of a grid connected transistor bridge inverter measured?
The performance of a grid connected transistor bridge inverter is typically measured by its efficiency, which is the ratio of output power to input power. Other factors that can be used to evaluate performance include the inverter's power factor, which indicates how well it converts power from DC to AC, and its total harmonic distortion, which measures the quality of the AC output. These measurements can help determine the overall performance and reliability of the inverter.
  • Electrical Engineering
12K
  • General Engineering
15K
